| JVT Header install |
| to install or not install my new hid's |
| TRD Spring Install Cost |
| Nitrous Accessories |
| HELP!!!! (LED installation) |
powerhouse21
anybody help me out with the WOT switch and how to install it? |
doock87
If you're just looking for the tps wire on the ECU, it's E8-21, a light green wire. Go to www.dezod.com to find the pinout diagram for the tC. If you don't want to do that, it's the harness on the bottom of the ECU, light green wire, 4 from the bottom of the car, 2 from the drivers side of the car. If you figure out how to get the TPS switch running, please post it here. Also, which kit did you buy again? |
powerhouse21
i got the ny-trex 4,6 Dry EFI system. |
powerhouse21
I think what i might do is turn the WOT into a push button and run that inside the car rather than mount it under the pedal...any reason not too? |
07TouringCoupe
I personally wouldnt use a push button to use n20, why because going at high speeds it's better to have two hands on the wheel rather than one on the wheel and one n20 button. Im not sure if it's capable with you setup, but i would get the TPS. (Throttle Position Switch) A car is only as good as it's driver. |
babydabbs
okay so i got interested in reading this. it is honestly soooo funny. half of the questions this guy is askin, i knew..well most of the questions i knew. powerhouse21 not to sound rude but i agree with nick, you shouldnt do nitrous to your car. not even with another guy helpin. you need to put it in a shop, and leave. let them do it, then ask them how to work it. you didnt kno where the maf or the throttle body. okay i kno where they are! and your title on here is 'oil changer'! im gonna go out on a limb, do you know where the oil plug is..or how to change your oil? ouch!! that was so wrong, but true. yeah im only a 'window washer', im a girl, and if i dont do most of the work to my car, i atleast help out. so go ahead boys, tell me how wrong i was to say this..whatever! it is funny!!!! aim sn; craziecowgurl17 |
lol are u serious? for DRY kits its pretty simple to do by urself, even wet kits but wet kits u have to cut into the fuel lines. dry kits is just drilling into ur intake, simple enough. |
powerhouse21
so i installed the kit today and it works like a charm. Thankyou to those of you who actually helped me out. |
Mugetsu
Cool did you go with the push button? or the mechanical WOT switch under the pedal? I'm not sure if you can tap in to the TPS wire on this car cause i don't know if it uses a dropping voltage one or a fixed one. i would prefer a "hand held" push button with a coil cord. any way, good to hear its working great, just be careful man, i would suggest a fuel pressure gauge and a nitrous "filter" just as precautions. what are you spraying 30, 50? wow that was more intense than that one time I forgot how to sit down... |
powerhouse21
right now im using a 35 shot. Because i was so anxious to get it tested out today i used the wires for the WOT switch and hooked them up to a push button but tommorrow i will mount the wot switch under the pedal. It wasnt too hard, drilling into the intake and running some wires. Took about 3 hours. And i have a fuel pressure as well as a/f ration gauge to make sure i dont get too lean. |
doock87
Have you stepped up the flavor yet? Start running a 75hp shot. You won't be disappointed. |
powerhouse21
nah man i ran into a problem. Now when i hit the button it only purges...now nitrous goes into the intake so i wired it up wrong |
nick06tc
Not to be a butt. But for your own protection, take the car somewhere and have it done. You are already having issues and its been 2 days. I know you want to do it yourself and save money, but the cost of an engine swap will not be good. You can choose only two when modifying a car: cheap fast reliable |
doock87
Uh oh, detail how you wired everything up and i might be able to help you fix this problem. |
doock87
Welp, i managed to nail all 3! All it takes is some time to learn how it's done. |
powerhouse21
yeah im gonna take it to ptuning on saturday and have them wire it up the correct way so i dont blow anything up. |
powerhouse21
Im curious for those of you who have a purge kit where you have it coming out. I have about 7 feet of tubing and i may split it to make it duel purge but im not sure yet... |
