Home > Performance Mods > Suspension & Brakes > HELP with rattling from springs
kskim20
North Carolina, US
so i have had my Hotchkis springs for about 2 days and there is a rattling comming from the front driver side spring mostly when i go over bumps...has anyone had this problem? what should i do?
[#] Sep 20, 2007 08:10pm
psiewert
Gurnee
Illinois, US
most likely it wasnt seated properly in the grooves. Either that or you didnt cut the bumpstop when you installed them
[#] Sep 20, 2007 08:18pm
The rattling is gonna be b/c it was seated properly against the bottom plate of the strut/shock. If the bump stop was getting in the way, you would get a bottoming-out clunk.
Check all 4 springs and make sure the edge of the bottom coil is position FIRMLY against the slight indentation of the base plate.
[#] Sep 20, 2007 08:55pm
TOP: Home > Performance Mods > Suspension & Brakes > HELP with rattling from springs
