| Cold Air Dyno Test/ F5Air, K&N, Injen |
| Toyota Responsible For Scion's Problems |
| Problem =\ |
| Problem with the HATCH!! |
| An Injen sp cold air intake |
jmscottza
Reg'd: Aug 27, 2007 Window Washer |
hi everyone, i just got the cold air intake by fujita, not long after i installed it i found out that it is rubing my chassies and i can clarely see damage to the pipe. i searched around and i found people having the same problem. then i found http://i6.ebayimg.com/02/i/000/8d/5d/0786_1.JPG the bottom right conrner piece i think that would help do you guys know if there is any thing like that on the market for the tc? |
JenWest
Reg'd: Jan 11, 2007 Scion Guru |
how did u find out this was happening and wat pipes were damaged so i can check mine ![]() |
sofresh23
Reg'd: Jun 04, 2006 Godlike Advisor |
there is .. someone makes it i forget whom .. but someone else will guide u.. other people fix this problem by simply putting sumthing inbetween ![]() ![]() |
sofresh23
its right where the piping turns downward into ur bumper just look at where the pipe starts curving down ![]() ![]() |
http://doctorisotope.com/...w&id=25&Itemid=29 This will hold the intake still while it travels into the fender well and keep it from scraping against the fender edge. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
JenWest
hahaha wanna hear a funny story...well when they installed mine they forgot tp put that piece in...im so mad ![]() |
You should be able to detach the center of the pipe enough (and remove the top of the fuse box) to riggle it into place. It's plastic so it's flexible. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
DevinN08tC
Reg'd: Jun 28, 2007 Tech Advisor |
Come on Jen, all that research I did into making the perfect cheep CIA set up and you let them install it with-out the heat shield? ;) |
JenWest
hahaha im so upset ![]() |
jmscottza
this is exatly what i was looking for thank you so much |
tc1stgen
Reg'd: Aug 12, 2007 Scion Guru |
I have a Fugita CAI and don't have this problem at all. I installed mine myself and apparently lucked out! Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen www.myspace.com/tc1stgen www.myspace.com/bochscionsouth "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
Ahh, So the Fujita CAI somes in two parts like the Injen one? ![]() "I have an idea! An idea so smart, my head would explode if I even began to know what I was talking about." - Peter Griffin -- Want to post a "For Sale" thread? Check out the rules first. |
Yes it dose⦠2008 G37 OB Sport 6MT... 2007 335I 4DR... |
tc1stgen
They sure do. From my understanding Fugita is a separate company but in someway related to Injen. Ask me about Innovative Car Works! LED's is their specialty! http://www.ItsMyScion.com/tc1stgen www.myspace.com/tc1stgen www.myspace.com/bochscionsouth "NOS is like a hot girl with STD's, you want to hit it but are afraid of the consequences!" |
DevinN08tC
The Fujita set up is a Complete Cold Air Intake. This set up being that it can be converted from a cold air set up into a ram air set up by removing the lower pipe at the coupler and installing the filter in it's place just like the Injen! Really all this means is that it rocks hard. |
curtislo9
Reg'd: Jun 20, 2007 Master Mechanic |
I had that same problem. If you don't care too much about looks, try to just get some thick rubber piping and wd 40 to put it over the area. It works like a charm. The piping is 3 bucks per foot? So it's very cheap. You can pick it up at any auto shop. |
DavidM21715
Reg'd: Jun 03, 2008 Window Washer |
I installed my Fujita CAI this past thursday along with Dr. Isotope's CAI fender panel install went great and mine hasnt rattled only slight problem i have is the part of the fender panel that is opposite side of the screw rattles when im idling but i think if i use like double sided rubber tape it'll stop it from rattling other than that I have nothing bad to say bout that part and it sounds mean when I acclerate. 10 out of 10 for this CAI!!! |
Kurisutaira
not likely i looked into this b4 installing my F5 Fujita and the piping is too longthe filter does not fit. so only a CAI is fees able SRI is unlikely unless u modify the pipe "This is what happens when an unstoppable force meets an unmovable object" |
^Correct...........Injen is the only intake, as of yet, that easily converts to a SRI. The rest require primary pipe (upper pipe to throttle body) manipulation. ![]() I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. A.E. |
when i installed mine i just put double sided rubber tape all around the fender openening.... |
