Home > Visual / Audio Mods > Interior Styling > help with neon lights
TCmafia
Pennsylvania, US
my tc came with the blue neon lights by the floor and in the cupholders... when i took out the console to install my dvd player, i unplugged the wires going to the leds for the cupholders but i reconnected them when i put everything back together but now none of the lights work(on floor or cupholders). any ideas? i checked all the connections... right after i did it, i noticed when i hit the switch to turn them on, they would flicker for a split second right when i pushed the button too(if that helps at all). thanks.
[#] Aug 31, 2007 02:08am
  • The Techie
connection probably came loose... the power is tapped to the cig. lighter.
Decelerate your life.
[#] Aug 31, 2007 01:49pm
TCmafia
Pennsylvania, US
no, i have checked connections many times already and it still doesnt work... the cig lighter works.
[#] Aug 31, 2007 03:50pm
envision
District of Columbia, US
did you cheak the fuse?
Want These icons pm me and i will make you one
-Released Day
[#] Aug 31, 2007 09:27pm
tcgrl05
Buford
Georgia, US
sooo... tc's come with neons, huh? wheres the switch at? i've got a switch in my car, but never really knew what it was for because it does nothing. i figured it was from the old owner.
[#] Aug 31, 2007 09:55pm
envision
they dont come with it. its a option to have installed. but the neons will be under the driver dash where your pedales are and in the pass side in the same spot. and cupholders.
Edit
if you go to my cardomain page you can see the cupholder leds http://www.cardomain.com/ride/2293929
-Released Day
[#] Aug 31, 2007 09:59pm
TCmafia
Pennsylvania, US
well, i figured it out. it hasnt been working for the last 4 months or so and just when i make a topic about it, i switch the wires under the console for the 10th time and it worked, go figure...
[#] Sep 01, 2007 12:10am
ymsredRturkey
if you can stay way from neons go with led's they last a lot longer and are brighter
[#] Sep 06, 2007 09:31pm
  • The Techie
well actually.. the factory option are LEDs. not neons.
[#] Sep 06, 2007 10:18pm
Auburn
Alabama, US
no no no Squall, it's those NEW type of lights
Neon-LED Hybrids
[#] Sep 06, 2007 11:44pm
ymsredRturkey
i just glanced at it looked like neons to me that or 2 leds and a plexi bar.....not to mention they stick out install on them sucks did mine myself so you don't see it
[#] Sep 08, 2007 02:24pm
TOP: Home > Visual / Audio Mods > Interior Styling > help with neon lights
