| TT vs. Dezod |
| TC VS COP car |
| Superchargers vs Turbos |
| hankook tires |
| Moped vs. Ferrari |
ypsetihw
so the stock rims come with 215/45/17 tires, and I'm looking into an aftermarket pair of rims with snow tires that have a 225/45/17 profile, but the reseller is a dunce and can't help me on this. 225 is the width in millimeters, and the question is, will I be able to fit my stock 215s on rims designed for 225 (cause I want my street tires on the gold rims), and more importantly, will the 225/45/17s fit my stock rims (the snow tires on my stock rims). Here's a pic of it photoshopped with the rims I'm lookin at. Thoughts? |
ypsetihw
also, as an afterthought, anyone know a good place to lookup info like this? maybe a graph with the sizes? i saw some stuff on tirerack.com, but i'm wondering if there is something a little easier to understand that I can look at to understand this whole tire/rim sizing issue. Thanks! |
SuperXero
whats the rim dimensions? 17x7? 17x8? |
ypsetihw
17x7 i found a site that said you can stick with 205-225 on a 17x7, would you guys agree? |
tc4metory
I know you can on 18" cause I went with the 225 as opposed to the 215.. check with Web, he knows everything, literally Chuck Norris is currently suing myspace for taking the name of what he calls everything around you. |
Rabid_Lemming
People stretch tires on wider rims all the time. Here is a link.... http://forums.vwvortex.com/zerothread?id=2234638 My car isn't the fastest car out there, but I'll tell ya.... Sometimes I haul more ass than a pimp driving a caddy full of hoes. Me to Pathik at PRacing.com about modding cars "It's like crack, but you don't lose as much weight...also you don't blow people for performance parts. So I guess it's nothing like crack" |
I've got 225/45/17 and it's 4 mm taller than stock....nothing much. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
Gonzo
just buy 18" wheels and stay low pro!!! |
SoFloTC
i have 235 ;o |
GoodOlS13
they will fit just fine |
emerilnut
Yeah, they'll fit just fine. I've run 225 tires on 15x6.5 wheels before, and it's no problem at all.. In fact, the cantilevered look of the tire looks pretty mean, almost like a race car. At least, that's what the Hoosiers looked like when they were on the race car. You might want to consider running 225/40/17 though to keep the rolling diameter similar to stock. That way, your gearing will still be correct.. if you get too much off, your speedo will no longer be accurate. 2008 Scion tC - completely stock for now... 1995 Mazda Miata - supercharged, MegaSquirted, soon to be a T3 Turbo... 1990 Mazda Miata - SCCA Club Racecar, ITA Class "Auto racing's boring except when a car is going at least 172 mph upside down." "I know that son-of-a-bitch is cheatin! Cuz I'm cheatin' and he beat me!" |
on a 17x7 rim? that's dangerous! 225 would be the max to stretch on a a 7" wide rims before you loose your sidewall integrity ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
nickah
what the....since 215 is stock, ....235 isn't wider?! whaa... You can't learn me nothin... |
henrygiang
so is there a big difference between 40 and 45? i am gettin 18x7.5 rims. |
You can't compare the difference in aspect ratios b/c they are in relation to the overall width of the tread. A 45 aspect ratio of a 215 is almost exact to a 40 aspect ratio of a 225. The thing you have to remember is that keeping the same aspect ratio on wider tire will give you a taller side wall thus, more rotational resistance. YOU WILL LOSE POWER TRANSFER! Also, be careful what you read online. People saying they have seen this on this, or they've done this with this....it's the math and safety that matters...not what CAN be done. A 7 inche wide rim will fit as small at 195mm tire UP TO 225mm tire SAFELY. Anything thinner or wider is going to bubble out or shift on the rim on turns, hard acceleration or hard braking. Just research the numbers rather than what people have seen or may have done. ![]() Complaining is futile when you supported the victory. http://clubsciontc.com/fo...-rims--5x100-pattern.html |
emerilnut
Agreed. I've seen even 235 series tires on a 7 inch wheel, but these were Hoosiers with VERY hard sidewalls on purpose built race wheels. But you do have to carefully weigh anecdotal examples. I agree. What worked for someone else might not work for you because they luckily had the right combination of parts to make it work, or they knew what the issues would be and took care of them beforehand. 2008 Scion tC - completely stock for now... 1995 Mazda Miata - supercharged, MegaSquirted, soon to be a T3 Turbo... 1990 Mazda Miata - SCCA Club Racecar, ITA Class "Auto racing's boring except when a car is going at least 172 mph upside down." "I know that son-of-a-bitch is cheatin! Cuz I'm cheatin' and he beat me!" |
henrygiang
okay.. thanks.. so my rims will be 18x7.5 and i was thinking about getting 225/40/18.. is that safe? how about 215/45/18. they will both be safe with my rims right? |
Yes. ![]() ![]() ![]() The Thread Killah |
jmazn
it will fit! i have a 225-45-17 go check my site you'll see hope it would help... need help and opinion witch would you choose? |
