Home > Marketplace > Sponsored Sales > Turbonetics Turbo kits
carcandy
Detroit
Michigan, US
  • Silver Sponsor
W/O Catalytic Converter
Item #: 15152
MSRP #: $4,995.00
Manual Transmission
Scion has revitalized the sport compact market and we have made the tC even better. The Turbonetics turbo system delivers 300 HP to the 2.4L 4 cylinder to make this car an absolute blast to drive. Phenomenal boost response in every gear, this kit runs 8.5 psi to deliver power all the way to redline.
Stock HP: 160
HP New HP: 300HP@8psi 140HP gain!
- Crankshaft horsepower with 94 octane fuel
- HP may vary based on difference in octane
INSTALLATION
• 6-8 hours install time
• No modifications to chassis required
• Quick spool up (minimum turbo lag) due to BB technology & correctly matched turbo
INCLUDED IN KIT
• T3/T4 E-50 Ball Bearing Turbo
• Spearco intercooler
• Raptor blow-off valve
• Evolution wastegate
• Unichip engine management
• Stainless oil feed line
• Taps for oil return and oil feed fittings
• Stainless down-pipe with wastegate dump-tube
• Cast ductile-iron exhaust manifold
• Black chrome mandrel bent aluminum intercooler pipes
• Silicone hoses
• High flow air filter
• 4 drop-in Motron high flow injectors
• T-bolt & V-band clamps
• Nuts, bolts and fittings
UNICHIP
The Unichip is a computer that electronically resides between your car’s ECU and engine or “piggybacking”. The Unichip computer is a solid-state computer made of multiple high-speed processors to fine tune engine performance. All Scion kits come with a Turbonetics programmed Unichip.
I got couple ready to ship. Pm me for a price to low to post
[#] Aug 26, 2007 06:58am
Lexington
Kentucky, US
  • The Gearhead
PM sent
[#] Aug 26, 2007 01:13pm
MrScion07
Rochester
Massachusetts, US
InLikeFlint hehe are ur going to boooost
[#] Aug 26, 2007 01:49pm
Lexington
Kentucky, US
  • The Gearhead
That's been the plan for about a year, especially since ZPI is out, All motor just went out the window.
[#] Aug 26, 2007 01:53pm
MrScion07
Rochester
Massachusetts, US
true that not alot of people out there doing that. i think Dezod might b selling stages for motor builds where they got a new shop going up. u should pm Paul over on SL and see about that.
[#] Aug 26, 2007 02:02pm
carcandy
Detroit
Michigan, US
  • Silver Sponsor
bump
[#] Aug 30, 2007 09:08am
rlinbatonrouge
Baton Rouge
Louisiana, US
That's a BIG jump in HP! Have y'all done many? Is there a big problem afterwards with wheel hop? I know FWD cars have an issue with that once you get up in the HP range.
[#] Aug 30, 2007 10:04am
carcandy
Detroit
Michigan, US
  • Silver Sponsor
never had any issues with this kit. The wheel jump depends on the way you drive.
[#] Aug 30, 2007 10:07am
rlinbatonrouge
Baton Rouge
Louisiana, US
Were the cars with this kit driven like at the track? Wheel hop can be fixed, I'm just wondering what to expect. In my experience, dropping a FWD car with 250+ WHP at anything over 1500 RPMS will cause it to wheel hop so hard your fillings will fall out of your teeth. Now if you baby it and drive very easily there is no issue. But coming off the line it sounds like the car is going to explode. Heck, even CTS-V's have this problem with RWD. GM has a TSB for that issue. Same with the 6.0 GTO, the STS-V, etc...
[#] Aug 30, 2007 11:09am
carcandy
Detroit
Michigan, US
  • Silver Sponsor
The cars are not babied in anyway. They both putting down 320 HP with stand alone fuel management.
[#] Aug 30, 2007 11:15am
Seattle
Washington, US
Get an LSD and don’t drop the clutch after 2500RPM.
2008 G37 OB Sport 6MT...
2007 335I 4DR...
[#] Aug 30, 2007 12:29pm
rlinbatonrouge
Baton Rouge
Louisiana, US
I know ways to correct wheel hop, what I wanted to know is if these car exhibited it with that HP. They state that it does not. Honestly, that surprises me but I don't have a reason to disbelieve them. It looks like a good kit.
Oh, and a LSD does nothing for wheel hop. Feathering the clutch will along with stiffer mounts, better tires, etc..
[#] Aug 30, 2007 02:43pm
miss_tc_tuner
North Tazewell
How much shipped to 24630, Tazewell, Virginia? Thanks!
[#] Feb 03, 2008 01:16pm
shadowracer684
Millburn
almost 5 k? ive seen this kit for for a thousand cheaper...
[#] Nov 30, 2008 08:35am
TheFantasticG
Tomball
Over a year ago? I've seen more recent posts...
[shameless plug]
Since Turbonetics is discontinuing the kit for the tC you can get it dirt cheap from www.turbochagers.com
[/shameless plug]
[#] Nov 30, 2008 11:32am
TOP: Home > Marketplace > Sponsored Sales > Turbonetics Turbo kits
