carcandy
![]() ![]() DM-5 + SM-AFR Price $254 shipped. Standard Digital Display Module and Air/Fuel Sensor Module Combo Universal 2 1/16" (52mm) Gauge and Air/Fuel Sensor Module Affordable 2 1/16" Standard Size (52mm) 0.7" (18mm) Thick Digital Accuracy Must connect to SM-AFR Module DESCRIPTION: SM-AFR accurately measures the precise air/fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system. SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge. We carry a full line of PLX Device products contact me for more information. Thank you Greg |
carcandy
Rabid_Lemming
Ahh I never even saw this. I always wondered, where is the optimal place to put the bung for af/r sensor? My car isn't the fastest car out there, but I'll tell ya.... Sometimes I haul more ass than a pimp driving a caddy full of hoes. Me to Pathik at PRacing.com about modding cars "It's like crack, but you don't lose as much weight...also you don't blow people for performance parts. So I guess it's nothing like crack" |
carcandy
it depends on your setup if you car N/A 24" downstream from your block and 36" if you boosting. |
carcandy
Check out this gauges you will love them. http://plxdevices.com You can design anything you want. |
carcandy
no one wants gauges? |
carcandy
bump |
carcandy
bump |
carcandy
bump |
carcandy
in stock |
J/W - how does this compare to the AEM UEGO? ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
carcandy
this is more accurate and has a built in pressure sensor in the controler box. |
Interesting. If I need to replace my UEGO I might consider this. ![]() Scikotics NJ is sponsored by Lawrence Scion 2006 GReddy Turbocharged Automatic tC 220+ WHP - 14.044 @ 97.02 MPH |
RusWolf
Thats the one i ordered from Greg and should be here next week, Nick soon you'll see this and other PLX gauges in person. On a side note Greg answered ALOT of my emails, and was very helpful. So people if you need anything ask him he'll tell you straight up if he has it or not and best price he can do !.. |
keys101
I just done see how this is accurate since regular guages have to hook up to what they are monitoring but it looks sweet.... |
carcandy
well the controller box is hooked up to wideband or other sensor you want to use. Gauge hooks up to the controller box. |
carcandy
carcandy
bump |
carcandy
bump |
blueturbotc
Not to bash your product bu the AEM is very accurate. The only one (from my research) that is better is the Innovate LC-1. |
SoFloTC
i got the UEGO aswell and i think its the most widely used a/f R in the states |
