| what color? |
| oil pressure gauge from block hook up question... |
| any difference in a 06 and 07 header |
| How to block unwanted calls? |
| FS: Sleeved Block/Built Head/Internals |
Due to a few requests, I'll explain the difference: Long blocks:
![]() Short block:
![]() ![]() Ignorance is bliss....305 fo life!...haha...Poser |
grlswannadance
Reg'd: Apr 08, 2007 Godlike Advisor |
is there anything u dont know? haha great job web! im sure this will really help some people out i know i didnt know it a car is a girls toy too ;] -- www.myspace.com/pinksquadowner --www.itsmyscion.com/caligirltiffy |
rlinbatonrouge
Reg'd: Jul 31, 2007 Tech Advisor |
Let's see if we can stump him then. What's the diameter of a tire valve stem, rounded to the nearest millimeter? |
hooligan
Reg'd: Apr 12, 2006 Detailer |
there are a few different types, ranging from 8mm to 16mm. just thought i'd beat Web to it. ![]() ![]() www.scionmilitia.com |
rlinbatonrouge
How about the burn temperature of the stock headlight in Kelvin? |
3800K ![]() Ignorance is bliss....305 fo life!...haha...Poser |
hooligan
hmm, thats a good question. whatever a 12.8volt 51 watt 9006 HB4 Sylvania burns at, which i believe is around 3400K haha ok i had to cheat for this one. i knew it would be under 4000, but to be exact i did some digging. ![]() ![]() www.scionmilitia.com |
Greddo
Reg'd: Jan 02, 2005 Tech Advisor |
Which part? At the wheel (rim hole) or the stem itself? Standard rim hole is 11.51mm (.453") or 15.88mm (.625") Stem diameters are: TR412= 9.40mm Length= 7/2" Valve hole= 11.51mm TR413= 9.30mm Length= 1-1/4" Valve hole= 11.51mm TR413 w/ chrm slve= 10.40mm Length= 1-1/4" Valve hole= 11.51mm TR414= 9.30mm Length= 1-1/2" Valve hole= 11.51mm TR415= 9.20mm Length= 1-1/4" Valve hole= 15.88mm TR418= 9.30mm Length= 2" Valve hole= 11.51mm TR423= 9.20mm Length= 2-1/2" Valve hole= 11.51mm Enkei Style= 7.70mm Length= 3/4" Valve hole= 11.51mm That's just some of the passenger stuff. There are a lot more. |
rlinbatonrouge
HAHA. Y'all crack me up. Some here either know WAY too much, or have too much time on their hands. |
hooligan
reckon its a lil of both. ![]() ![]() www.scionmilitia.com |
Greddo
^^ yup yup ^^ & WEB is sick wit it among many others... |
rrimportracer
Reg'd: Feb 28, 2006 Godlike Advisor |
x2 ![]() myspace.com/asphalt_photos check us out!!! |
nick06tc
Reg'd: May 20, 2006 Scion Guru |
Not to knock what people know, but GOOGLE can answer each and EVERY one of your questions. Web deffinetly knows his stuff, but What is a short and long block? can be answered by typing in long block into wikipedia. Takes about 10 seconds to find the answer he posted. The valve stem sizes can be found on tirerack.com. Forums are great for info, but most of it is just a meeting place for other info that is out on the net. |
