| JDM Fog lights with rs1 lip |
| need help looking for fog light |
| RS 4.0 Fog Lights |
| Independant power for FOG lights |
RouletteTc
Reg'd: Jul 06, 2007 Scion Guru |
First off, I'm sure this install will apply to the VRD's, which are also outer fog lights. The kit you can order from xtralights.com comes with everything. This install is about a 4/10 and take about 1.5hrs to 2hrs if you are experienced. It took me 5hrs without directions and making a stop to Autozone for fuses. All you need is a socket wrench kit, 2 car stands, wire cutter, circuit tester, electrical tape, zip-ties, and maybe some spare 7.5 fuses. **SORRY**: I do not have the parts layout, because they are already installed, but you can figure out which wire goes where and how they connect from the pictures. So first off you want to raise the car up then unscrew these corner panels underneath the bumper. These are the panels in front of the wheels. There should be about 5 screws and then it comes right off. ![]() Next you want to pop out the older corner scoop pieces and insert the fog lights with the bracket on the inside of the bumper. The fog lights screw into the bracket holding it snugly in place. ![]() Next, start to connect the wires so that you can feed them up to the battery. You do not need to remove any of the other pieces of the bumper just push the wires up in and then pull them up the front of the radiator. ![]() You can mount the volt box and spark plug to a screw on the front of the radiator as shown. ![]() You can now connect those bottom bumper panels and lower the car down. Now, on to the battery, pop this red cap off the positive end of the battery. Originally, the screw is facing the intake, but I reversed it so that it can be easily taken off again. The red wire has a screw hole so the screw can fit through it and mount it. ![]() You do the same with the black wire except on the negative end of the battery. ![]() Now, begin to feed the wires along the hood lining (top of bumper). ![]() Use an old metal hanger to feed this wire through a small slot into the control box inside the car. ![]() The wire will come through on the left side, when sitting in the car. You pull it past the door crack then tuck it behind the weather strip and push it into the wire box. ![]() Go ahead and pop on the oem switch. ![]() The light green wire is a wire that I used from the unused wire harness. You can circuit test any wire to find out which one is hot. Splice the hot wire and connect the red wire to it. Then solder or use electrical tape. Unused wire harness in top right corner of picture ( CREDIT to BRETTF3588 ) ![]() ![]() By the way this is the fuse that continuously blew on me. It's the large 7.5 one that is raised higher than the others. This is the fuse box inside the car. I had no problems with the engine fuse box. ![]() Now, just clean up and you are done. It would be wise to use the zip-ties provided so that you can secure the wires to a comfortable and safe position. Feel free to test the lights as you go along to make sure things work. After everything is done you need to reprogram the windows and sunroof. From, the driver's side hold the switch up for three seconds then test the windows for motion and auto feature. Then repeat from the passenger side door. Moonroof programemd itself for me so I don't know if you will need to, but it's the same way, 3 seconds. **EDIT** I forgot to picture the ground wire. That wire is also red and there is a good ground screw inside the wire box where you connect the switch. It is inside and to the right, you can't miss it. And here is the final product: Fog lights off... ![]() Fog lights on... ![]() -Thanks for the sig Aciidsneaker |
Great wright up... 2008 G37 OB Sport 6MT... 2007 335I 4DR... |
soCAL-tc
Reg'd: Oct 24, 2006 Scion Guru |
^x2, great job! |
o7SCIONtc4gg
Reg'd: Feb 07, 2007 Scion Guru |
nice job bro. thanx to u now it will b easier for my install ![]() ![]() ![]() |
Sticky ![]() Ignorance is bliss....305 fo life!...haha...Poser |
RouletteTc
Thanks guys, it took me like 5 minutes to write, haha just getting around to it was the hard part. ![]() -Thanks for the sig Aciidsneaker |
Fliphm00b
Reg'd: May 20, 2007 Chief Mechanic |
cool man ty ill prolly get the blacked out ones or might just order the vrd fogs =) ![]() |
StARDuSt_tC
Reg'd: Jul 05, 2007 Tech Advisor |
great DIY! i'm in love with those fogs!! Looks GREAT! |
brettf3588
Reg'd: Jun 20, 2007 Tech Advisor |
ok this might be stupid...but coming out of the volt thing, where are 3 wires with black covering, 1 being the fuse or what ever looking thing....the other 2 have a little black plug thing on the end....what are they and where do they go??? EDIT*** nvm im a moron, they connect to the fogs itself -07BSPtc- |
RouletteTc
Haha yea I didn't post that part I figured connecting all the wires was kind of self-explanatory, and as you can see you figured it out. ![]() -Thanks for the sig Aciidsneaker |
brettf3588
yea, it totally passed my mind, but i figured it out when i was thinking, how are they gonna be powered?? lol -07BSPtc- |
i wanna get the VRD ones, they look t3h s3x |
triniosito
Reg'd: Nov 15, 2006 Godlike Advisor |
2x ![]() |
Lucky
Reg'd: Aug 06, 2007 Tech Advisor |
Pics of the front of the car with the new fogs on?? The b's B! Objects in mirror are more stable than they appear. Objects in mirror are less sideways than they appear. Real men do it sideways...you wouldn't understand. Representing the ULTIMATE RIDE! TUNER TRIFECTA |
RouletteTc
Check my profile ![]() -Thanks for the sig Aciidsneaker |
Lucky
Damn...those looks HOT! How's the functionality vs the stock fogs? I may have to do this...modified a little The b's B! Objects in mirror are more stable than they appear. Objects in mirror are less sideways than they appear. Real men do it sideways...you wouldn't understand. Representing the ULTIMATE RIDE! TUNER TRIFECTA |
RouletteTc
They are extremely bright and add about 6 feet of light to the sides, which the factory fogs cannot do. Also, just tested them in the rain, drove 45min in pouring rain, no moisture in the lens' and they still work great. ![]() -Thanks for the sig Aciidsneaker |
Lucky
Awesomenes...time for my first lighting mod The b's B! Objects in mirror are more stable than they appear. Objects in mirror are less sideways than they appear. Real men do it sideways...you wouldn't understand. Representing the ULTIMATE RIDE! TUNER TRIFECTA |
ilovemytC
Reg'd: Aug 15, 2007 Detailer |
Good write up! I tapped a brown wire in the harness so they would turn on with the parking lights. These fogs are perfect fitment and very easy to install! |
Lurkin
Reg'd: Oct 10, 2007 Window Washer |
Thanks so much for this guide, I just got my JDM fogs yesterday and there were no instructions or anything with them, kind of annoying but thanks to you I had everything I needed. So after work today I got to work on this and it only took about 1 1/2 - 2 hours to complete this which is not bad at all and they work and look great. The light green wire turns them on and off with the parking lights which I love. Thanks again for the write up. Now I gotta find one for installing my new projector halo headlights that are coming any day now. |
RouletteTc
That's why I wrote it. Glad it helped you out. ![]() -Thanks for the sig Aciidsneaker |
I just saw this thread, haha. Awesome write up! ![]() "gonna wash my car before i take a nap.. can't rest well knowing i've got the entire cast of A Bug's Life on my bumper" - Vicious -- Want to post a "For Sale" thread? Check out the rules first. |
blaszczykl
Reg'd: Jun 16, 2005 Detailer |
you can also slice the red wire from the switch into the parking lights wire here is a pic ![]() there are two brown wires you can slice to either one of them and here is a pic of JDM fog lights with NIAbodykits ![]() |
RouletteTc
Did you have to do any shaving for them to fit that lip kit? ![]() -Thanks for the sig Aciidsneaker |
blaszczykl
yea I need to to dremel out the part that goes inside the bumper |
