| DIY: How to make your icon have 2 pictures next to it |
| DIY: How to Seafoam your engine |
| How NOT to unload your new car |
| Show how you mount your HID ballast |
You could do that, but its not as clean of an install. The piece is less then a dollar, lol. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
NewJersey
okay thanks alot, and does anyone know how to put the dome lights back up using both sides of the clips? |
Sorry, missed oyur other question. Mine just popped back in. Did you pull the clips out of the roof, or did they pop out of the housing when you removed it? ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
NewJersey
the white hive looking things are still in the roof. everything else came off |
You need to pull those out of the roof and clip them back into the dome light before you try to put it back in. If you don't have a panel puller, just use a set of needlenose pliers. Those little white clips were supposed to come out with the dome light, but sometimes they are a little stubborn. I had the same issue with mine. The clip on the left side didn't come out with the fixture and I couldn't figure out why I couldn't get the damn thing back in, lol. ............... ![]() ![]() ![]() Search or one of these adorable kittens WILL DIE! |
NewJersey
alllrightt perfect... thanks alot for the help ill try the hardwire todayy |
BearZ
I know, bump from the dead..but I have a question... I drive a Camry, I dont have a moonroof, my dome light has just 2 wires would I be able to use the power from the light wires to hardwire the detector? EDIT: I have a Cobra ![]() ![]() Check out my Deviant-Art Gallery |
As long as you tap into the constant hot wire and not the wire that requires you to push the light on to be activated. Find the main wire leading to the lights (which probably splits) and tap into that main wire. ![]() Complaining is futile when you supported the victory. |
BearZ
^ I think there 3 wires altogether and dont know which ones are which! theres 2 lights in the dome, I will take some pics later ![]() ![]() Check out my Deviant-Art Gallery |
O5_TRD_tC
nice DIY! The 4 LED_Headz: Ed (etli), Trung (SquallLHeart), Alan (O5_TRD_tC), and Paul (Dakine) |
Thanks Bearz...Yeah, post a pic ![]() Complaining is futile when you supported the victory. |
CatalepsicFox
nice write up I actually gotten mines wired up on from the Cig Lighter![]() Fi8ureM.com - TheFi8ureLifestyle - Coming Soon! - MySpace |
epidemic
really likin this write up. a radar is next on my list soon |
darkshadow89
thanks man, i too was going to run a wire all the way to my circuit panel |
That would have been a pain to run the wire due to the panels you have to remove. Glad this helped. ![]() Complaining is futile when you supported the victory. |
enzo5190
this worked out perfectly for me with my cobra xrs r9g!!! |
