| DIY: Hormel Chili |
| DIY: How to make your icon have 2 pictures next to it |
| DIY: How to Seafoam your engine |
I have the Beltronics RX-65 and wanted to mount it up and out of the way to get the best RADAR detection (not laser b/c laser is best mounted low) and to keep it very clean. Here's how I did it: Tools -plyers/crimpers -10mm socket -3/8 ratchet (or just a small one b/c there's no room) ![]() Steps: 1: Open hardwire package you ordered (this was mine) ![]() In the picture, RED, is an inline glass fuse, GREEN is the detector power connection, BLUE is where you will tap into a power wire, and YELLOW is the ground. The blue object is the T-tap the kit comes with. 2: Remove the dome light by pushing the ceiling panel up a bit to fit your fingers where the BLUE circle is. Pull down pretty hard and work your way towards the two RED circles. There are a total of 3 pressure clips on the back. ![]() ![]() 3: Locate the moonroof motor plug ![]() 4: For ease of installation, unplug the dome light plug (YELLOW...the RED is the moonroof motor) ![]() 5: Look inside the hole in the ceiling panel and to the left (driver's side). That's a 10 mm bolt you will use for a ground. ![]() 6: Locate the ORANGE wire on the moonroof motor plug. That is the wire you will use the T-tap on. ![]() 7: Remove the 10 mm bolt for the ground, position the ground and then re-tighten it down FIRMLY ![]() 8: Slide the spade connector into the T-tap for power ![]() 9: I tied the wire up and tucked it up to the left in the hole ![]() 10: From the inside of the hole, push down on the ceiling panel a bit up front to allow a gap to feed the wire connector through ![]() 11: Position and mount your detector ![]() ![]() ![]() Enjoy ![]() Ignorance is bliss....305 fo life!...haha...Poser |
Sweet DIY! And to think my dumbass was going to run the hardwire all the way to the fuse box... Thanx ............... ![]() ![]() ![]() Donate or one of these adorable kittens WILL DIE! |
No problem ![]() Ignorance is bliss....305 fo life!...haha...Poser |
MrScion07
Reg'd: Sep 09, 2006 Godlike Advisor |
is that the new one with the new setup u got web? ![]() |
Yeah, that's my new detector with my harness I ordered from beltronics. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
I had a ground issue the first attempt and got everything back up and cleaned up and when I started the car, it didn't work! I took it all apart again and found that the ground was loose in the crimp connection. I just replaced it and it worked. The T-tap is a bit loose but I taped it in place and have no issues with it now ![]() Ignorance is bliss....305 fo life!...haha...Poser |
MrScion07
id liek to see a test isnt that the kit that supose to jam the radar for like 10 seconds or so? ARNT GROUNDS A B*TCH ![]() |
No, that's just a direct wire kit. It doesn't do any jamming or anything else. Basically, rather than having a big cord hanging, it's all tucked away and just direct power-drawn from a constant-on power supply (sunroof motor when ignition is on Yes...yes they are. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
MrScion07
Nice DIY anyways I thought u were getting some sort of radar jammer? ![]() |
I was thinking of it but it's pointless. They were laser jammers. Honestly, if I get pulled over while getting tagged by laser, it's my fault anyways so whatever. I'll bite the bullet.......but I rarely speed and mainly just cruise. The detector is just for speed traps that I know are set up just for an annoyance and "end of the month" quota catches. Just an early warning, not a speeding helper. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
Aciidsneaker
Reg'd: Feb 24, 2007
Nice Write up Web, Question, Where did you order the kit from? direct me to the site? do they have a kit for other models? I believe I have a Cobra 12-Band Radar/Laser Detector. ![]() ![]() Scion Wiki ~~ |
^That's the XRS9430 that I'm selling http://www.clubsciontc.co...or-my-radar-detector.html agent009_5 had it. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
Aciidsneaker
Reg'd: Feb 24, 2007
K thanks Web ![]() ![]() Scion Wiki ~~ |
NP ![]() Ignorance is bliss....305 fo life!...haha...Poser |
Just a quick update on how the detector is doing mounted up there: Great! I just came around a corner today that was marked at 30 in the community and then opens to 45 for the backroad. Very tricky location and a CLASSIC cop-stop around my area. There is a constant K meter there but today, right when I picked up that meter it went from 1 bar all the way to max alert instantly. I look up the hill into the sun glare and see a figure standing outside infront of a white Crownie. Yeah, definately aiming right at me with K band radar. So, mounting it up that high is not compromising my radar detection. Laser may be no longer completely accurate, but I don't really care much about that. Maybe later, if I decide I "need" it, I'll get the M20 blinder laser jamming kit. ![]() Ignorance is bliss....305 fo life!...haha...Poser |
brettf3588
Reg'd: Jun 20, 2007 Tech Advisor |
very nice DIY web...def gonna think about doing it, but i would need a Cobra hardwire kit....if u find any info (besides the DIY you posted in an earlier reply) let me no....thanks -07BSPtc- |
http://cgi.ebay.com/Cobra...egoryZ88748QQcmdZViewItem Fits all Cobra detectors! Same plug And if you don't trust ebay: http://www.bestradardetec..._Cord_p/420-030-n-002.htm
brettf3588
aight thanks web..hopefully ill get it soon -07BSPtc- |
Aciidsneaker
Reg'd: Feb 24, 2007
Thanks Web. ![]() ![]() Scion Wiki ~~ |
no more M20 get the M25, more improved |
I just did this, and it was a very easy install. Took me about 15 minutes. I was unable to get one of those t-taps. I went to auto-zone, pep boys, and an independent electrical store, and none of them had it. ............... ![]() ![]() ![]() Donate or one of these adorable kittens WILL DIE! |
alright well i'm doing this when i get home tomorrow and i was wondering if anyone knew which type of sensor cops use in LA the most. that way i can just mount it out right the first time. Thanks! ![]() ![]() ![]() Are you in SoCal? Come to our CStC meets! Located in Socal? Need something Installed? Have a question and no one is willing to help? Shoot me a PM or hit me up on AIM. |
OldJersey
Reg'd: Jan 09, 2007 Vehicle Designer |
whats an alternative to using a t-tap, can someone explain it better to me, or if i need one, where can i get one, i have the kit but no t-tap. also, when i try to put my dome light back up it doesnt catch both sidesof the clips.. it either gets the two towards the front of the car OR THE BACK i cant seem toget it fully clipped ( any suggestions )???? |
http://www.tessco.com/pro...pId=620&subgroupId=24 Scroll down to splice connectors and that's what they look like. I got one at autozone. I was the red one that I used. ............... ![]() ![]() ![]() Donate or one of these adorable kittens WILL DIE! |
OldJersey
ok, so autozone should have them? and couldnt i just splice the wire with a wire cutter thing and then wire it together and use electrical tape? |
