| lights out.. help? |
| HID kit shorting out |
| Check these out.......... |
| :( HELP:( Blacked out ECU |
| Out of shape much? |
Word
i wanna get these http://www.lakeshorewheel...m/hpd/Spinout-Black.shtml in 19's i was wondering what all i need to take in to account and size's before i have rubbing...and if i would be able to lower my car |
rrimportracer
you should be ok on 19s but you gotta watch out for the width, personally I dont like those wheels, but whatever suits your taste ![]() myspace.com/asphalt_photos check us out!!! |
SoFloTC
looks similar to the Konig Unknowns.. those have no problems with rubbing or anything , check into those, they look a little nicer to |
Word
I looked up the Konig unknowns.... they do look better i like them so what you said was that the 19X8 rims will fit with no rubbing? and if so what size tires have you seen on it? |
8" wide is gonna be a tight fit unless you get a nice offset. Make sure the offset is at LEAST 42-45 b/c that's still gonna be pretty close. 235 should fit fine on them with that offset but if you want to be lowered, then pay VERY close attention to the rim offset. ![]() Complaining is futile when you supported the victory. |
SoFloTC
they dont got 19x7.5? |
nickah
higher the offset number means the more flush the wheels will be right? Or the more they will stick out? You can't learn me nothin... |
The further out from the center of the hub they will be....more lip. But that's good b/c you want it away from the inside fender when turning. ![]() Complaining is futile when you supported the victory. |
