| WTB: SRI for 07, new or used |
| WTB: Ingen Intake (used) |
| HELP!!! Before I buy... |
| used rims? |
| Read This Before Buying! |
SoFloTC
ok so theres an injen exhaust on ebay.. for like 240 he says hes been using it for 6 months it kinda looks rusted... but the back muffler part is shiny and new looking is there any danger of buying this http://cgi.ebay.com/ebaym...QQitemZ270148470270QQrdZ1 |
Looks ok but just make sure that if it came with a gasket that you get a gasket with it. ![]() Complaining is futile when you supported the victory. |
soCAL-tc
luckily our cars haven't been around enough to be cheated on time used...lol...nevertheless, that one looks to be in good condition...however, most times we pay almost the same price we would get it used... |
SoFloTC
whats a gasket ;x |
youngflyer
i think the danger is virtually zero on this one...the exhaust looks fine other that the heat discoloration but thats normal. as web said, make sure is comes with the gasket! ThE JeWiSh PiMp |
SoFloTC
does the giant rusted thing that i can see hanging from the back of my car (part of the exhaust) get replaced by this? |
yup. that is the muffler. its like a horizontal oval canister looking thing right? |
A piece of material that goes between the 2 joints that meet. Midpipe and Rear section...it may or may not need/have one. ![]() Complaining is futile when you supported the victory. |
SoFloTC
ya that ugly thing looks like a giant cylinder going across |
yup that gets replaced |
SoFloTC
if it doesnt come with gasket where would i find one |
soCAL-tc
gaskets are made of different materials...they're usually placed in between the flanges of headers, pipes and heads...nevertheless, they're function is to keep the pieces from touching metal on metal...and to make the fitting a bit more snug of course to avoid leaks...both pressure and air although one generall means the other..,lol |
Check with Injen or Scion. ![]() Complaining is futile when you supported the victory. |
soCAL-tc
muffler shop, they have plenty...even autozone, if you have to all you have to do is have your muffler guys or shop weld a new flange so that you could fit universal gaskets...however you could probably use a universal one with a few cuts here and there. |
SoFloTC
so then it SHOULD be coming with a gasket correct |
No idea.........just depends on the joint and how it's going to connect. ![]() Complaining is futile when you supported the victory. |
why dont u just ask the seller? |
soCAL-tc
not necessarily, you might want to ask him....if it's a true tc axleback you'll have the same style flanges so you probably go to scion and get some new ones...they get worn and tear fairly easily after being used, so it depends on how burnt their's is... |
SoFloTC
well hes had it for 60k miles ... |
in ur initial post u said it was used for 6 months, but for 60,000 miles? 60k miles in 6 months? |
SoFloTC
ya i meant 6 months my bad |
gasket SHOULD be ok, but if its just a normal flange, u can get em for like $0.50 at toyota/scion lol just ask the seller if it comes with the gasket, and also ask Injen if it uses the OEM Gasket size |
SoFloTC
just purchased it |
SoFloTC
he said i can use the stock gasket? |
