| Torque Stock Rims/Tires |
| weapon r torque damper |
| Engine Coolant |
| engine prob?? |
carcandy
![]() Ingalls "Stiffy" Engine Torque Damper Applications: SCION TC 2005-2006 Ingalls new "Stiffy" torque damper is a elastomer shock that mount via 7 gauge steel brackets between the engine and the chassis, reducing or eliminating power robbing movement improving off-the line acceleration for your vehicle. The "Stiffy" has hardened spherical rod ends, aerospace grade fasteners, 6061-T6 Aluminum body and an adjustment range of 6.75" to 7.2". Greatly improved off-the line acceleration. Reduced wheel hop. Improved vehicle stability. Reduced shock loads on driveline components. Smoother shifting. Reduced wear on exhaust system joints. Less vibration transmission to the driver compared to polyurethane dampers. Price: $167 shipped. Thank you Greg gregb@carcandymotorsports.com |
SoFloTC
What exactly does this do ? |
carcandy
updated post. |
bump...........great product. ![]() Complaining is futile when you supported the victory. |
carcandy
Anyone? I got 5 in stock ready to ship. Greg |
Imagin
They prevent the engine from moving back and fourth under acceleration. tC's have horrible movement in the engine bay, i think ive heard up to 4 inches forward and backwards. The Stiffy prevents that from happening. The issue with them is, it makes a HELL of alot of noise. Ive seen a fix to help with the noise by using a small rubber gasket and a washer, keeps it from jittering metal to metal at the firewall joint. I want to buy one, but believe me i will do the quick fix to stop the NOISE for the most part BTW i can get the stiffy for $130 bucks so sorry i cant go with the $157 your pricing them at. Hope you can sell them and make your profit ZPI makes another version but i dont like it. Its a steel bar that mounts underneath the engine and pretty much prevents any movement at all. You want a little bit of play, nowhere near how much the stock tC moves, but the ZPI is far too hard on the engine because it prevents even slight movement. PLus with ZPI you never know when your going to get your parts.... |
Bump for the night....great product. ![]() Complaining is futile when you supported the victory. |
carcandy
The lowest I can do $150 shipped. |
That's a great price for this and since he's a clubsciontc vendor, you can at least rest assured that he's a good business partner. ![]() Complaining is futile when you supported the victory. |
carcandy
price drop. |
I'll be picking one of these up in the near near near future guarranteed! ![]() ![]() ![]() The Thread Killah |
carcandy
sounds good let me know when you ready, I am of to Elmhurst for the show. |
carcandy
? Bump? o_O ![]() ![]() ![]() The Thread Killah |
Greg PM a price please, this is my next mod |
carcandy
pm sent. got more in stock. |
carcandy
Anyone? |
psiewert
whats the price? ![]() |
carcandy
$142 shipped. |
tCFM08
will this work also on automatic transmissions ![]() ![]() |
java09
i dont think transmission would come in to play as far as fitment.. now comes my fitment question.. fit an 08? thanks. 2008 Turbo Scion tCizzle POWERED BY TURBOTOYOTAS! 310WHP, 272WTQ more to come_.. |
tCFM08
so it would be ok for a/t then, and yeah how about 08 fitment ![]() ![]() |
java09
im thinking it will because i think the only changes from 06 to 07 then to 08 was some oil lines and the MAF sensor but i've been wrong before.. ill ask rabid. 2008 Turbo Scion tCizzle POWERED BY TURBOTOYOTAS! 310WHP, 272WTQ more to come_.. |
carcandy
It will work on any transmission and it will also work on 2008 tc, installed one last week. |
tCFM08
i once heard these should only be installed in engines that are supercharged or have a turbo kit, not like mine which i do not plan on adding any of those ![]() ![]() |
