Home > Visual / Audio Mods > Wheels & Tires > What tire size is best?
BlackTC185
Chalfont
Pennsylvania, US
Hey everyone I'm ordering 18x7.5 Enkei Evo 5 wheels in machined black, 35mm offset. I need to decide, however, which tires I want on them. I want low profile of course but I don't want them too small. I was thinking 215/35R18's but I'm open to suggestions. Any better ideas or what do you guys have on your 18" wheels? Thanks.
You've got a date rapist face.
[#] Jul 19, 2007 02:47pm
slickshot
Virgin Islands, US
try 215/45/18's or 225/40/18 those should work!!
Failure to Plan is Planning to Fail.
[#] Jul 19, 2007 04:24pm
225/40/18 would be a good size. DON'T GO BELOW 40.....they are paper thin and good luck when you hit a pot hole at 50+ mph.
[#] Jul 19, 2007 04:25pm
slickshot
Virgin Islands, US
i had a friend do that to his 00 mustang a month ago...it wasnt pretty at all
[#] Jul 19, 2007 04:30pm
Yeah, 30 series tires are way too thin and NOT street practial.
[#] Jul 19, 2007 04:35pm
Triniosito
2x nto worth it
[#] Jul 19, 2007 11:11pm
Lexington
Kentucky, US
  • The Gearhead
225/40 is perfect setup for 7.5" wheels and keeping stock rotational circumferance
[#] Jul 19, 2007 11:33pm
BlackTC185
Chalfont
Pennsylvania, US
Thanks man I'll go with those. I wanted my speedometer to stay dead on and to avoid tire wear.
[#] Jul 19, 2007 11:44pm
tc95050
Sacramento
Yeah stick w/ 40's. Just watch out fer curbs.
[#] Jul 19, 2007 11:53pm
SooSuave11
Sterling Heights
Michigan, US
yup 225/40/18's are the best route. I rock 215/35/19s and yes they are paper thin but dayum do they turn some heads lol.
[#] Jul 20, 2007 12:00am
  • $upervillain
i have 18" 7.5 enkei's and i'm running 235 40 18's. They're a little taller and a little wider and fit like a glove.
[#] Jul 20, 2007 02:21pm
What's the offset b/c that's a wide tread to fit under there. My offset on my 17x7 is 38 and with the 225/45/17s, they are about 2-3mm from being flush with the outside of the fender.
[#] Jul 20, 2007 02:22pm
  • $upervillain
good question? they're the optional one's you can get from the dealer. I just checked the faq site and it doesn't give the offset for the 18's, just the 17's. the extra width towards the outer edge isn't that much. i could probably still fit 10-15mm spacers in there if my car wasn't lowered.
[#] Jul 20, 2007 02:29pm
  • $upervillain
^ that's only at the top of the fender well, though. it sticks out past the fender at the bottom
[#] Jul 20, 2007 02:30pm
  • $upervillain
here's the differnce in the two tires:
225/40ZR18
92W XL
360 AA A UTQG
1389 lbs. Max Load
50 psi Max Pressure
11/32" Tread Depth
26 lbs. Tire Weight
7.5-9" Rim Width Range
8" Measured Rim Width
9.1" Sect. Width
8.4" Tread Width
25" Overall Diameter
827 Revs per mile
235/40ZR18
95W XL
360 AA A UTQG
1521 lbs. Max Load
50 psi Max Pressure
10/32" Tread Depth
25 lbs. Tire Weight
8-9.5" Rim Width Range
8.5" Measured Rim Width
9.3" Sect. Width
8.6" Tread Width
25.4" Overall Diameter
817 Revs Per Mile
As you can see, they're pretty combrable. These are avon mach 550's
[#] Jul 20, 2007 02:42pm
soCAL-tc
Los Angeles
225/40ZR18
92W XL
360 AA A UTQG
1389 lbs. Max Load
50 psi Max Pressure
11/32" Tread Depth
26 lbs. Tire Weight
9.1" Sect. Width
8.4" Tread Width
827 Revs per mile
235/40ZR18
95W XL
360 AA A UTQG
1521 lbs. Max Load
50 psi Max Pressure
10/32" Tread Depth
25 lbs. Tire Weight
9.3" Sect. Width
8.6" Tread Width
817 Revs Per Mile
225/40's...can't beat that, perfect combo...will fit with most springs and give the nice low profile look for you high rising tc's...
[#] Jul 20, 2007 04:22pm
BlackTC185
Chalfont
Pennsylvania, US
The offset of the wheels I ordered is 35mm and I'm putting S. Tech springs on so I hope all will fit well. Thanks alot for all the info this is why I love this site.
[#] Jul 20, 2007 05:48pm
TOP: Home > Visual / Audio Mods > Wheels & Tires > What tire size is best?
