Home > Performance Mods > Suspension & Brakes > Strut bars and Sway bars....what's the difference?
Reg'd: Apr 17, 2006
THE SHADOW
For those of you who aren't sure (and there's a lot of questions that pop up about it on random threads), I'll post the difference between what sway bars are/do and what strut bars are/do.
Sway bars: (also called anti-roll bars)
HowStuffWorks.com wrote:
Stabilizer bars are part of a car's suspension system. They are sometimes also called anti-sway bars or anti-roll bars. Their purpose in life is to try to keep the car's body from "rolling" in a sharp turn.
Think about what happens to a car in a sharp turn. If you are inside the car, you know that your body gets pulled toward the outside of the turn. The same thing is happening to all the parts of the car. So the part of the car on the outside of the turn gets pushed down toward the road and the part of the car on the inside of the turn rises up. In other words, the body of the car "rolls" 10 or 20 or 30 degrees toward the outside of the turn. If you take a turn fast enough, the tires on the inside of the turn actually rise off the road and the car flips over.
Roll is bad. It tends to put more weight on the outside tires and less weigh on the inside tires, reducing traction. It also messes up steering. What you would like is for the body of the car to remain flat through a turn so that the weight stays distributed evenly on all four tires.
A stabilizer bar tries to keep the car's body flat by moving force from one side of the body to another. To picture how a stabilizer bar works, imagine a metal rod that is an inch or two (2 to 5 cm) in diameter. If your front tires are 5 feet (1.6 meters) apart, make the rod about 4 feet long. Attach the rod to the frame of the car in front of the front tires, but attach it with bushings in such a way that it can rotate. Now attach arms from the rod to the front suspension member on both sides.
When you go into a turn now, the front suspension member of the outside of the turn gets pushed upward. The arm of the sway bar gets pushed upward, and this applies torsion to the rod. The torsion them moves the arm at the other end of the rod, and this causes the suspension on the other side of the car to compress as well. The car's body tends to stay flat in the turn.
If you don't have a stabilizer bar, you tend to have a lot of trouble with body roll in a turn. If you have too much stabilizer bar, you tend to lose independence between the suspension members on both sides of the car. When one wheel hits a bump, the stabilizer bar transmits the bump to the other side of the car as well, which is not what you want. The ideal is to find a setting that reduces body roll but does not hurt the independence of the tires.
Strut bars:
Wikipedia.com wrote:
A strut bar or strut brace is a mostly aftermarket car suspension accessory used in conjunction with MacPherson struts on monocoque or unibody chassis to provide extra strength between the strut towers.
With a MacPherson strut suspension system where the spring and shock absorber are combined in the one suspension unit, the entire vertical suspension load is transmitted to the top of the vehicle's strut tower, unlike a double wishbone suspension where the spring and shock absorber may share the load separately. In general terms, a strut tower in a monocoque chassis is a reinforced portion of the inner wheel well and is not necessarily directly connected to the main chassis rails. For this reason there is inherent flex within the strut towers relative to the chassis rails.
A strut bar is designed to reduce this strut tower flex by tying two parallel strut towers together. This transmits the load of each strut tower during cornering via tension and compression of the strut bar which shares the load between both towers and reduces chassis flex.
A direct result of this is improved chassis rigidity (similar to that gained from a lower tie bar); hence, the understeer is reduced, tire wear improved and metal fatigue is greatly reduced in the strut tower area. Following the aftermarket's lead, some manufacturers have started fitting strut bars to performance models, including the Nissan Skyline, Mazda RX-8, Acura CL Type-S, BMW e46 M3 CSL, Mitsubishi Lancer Evolution, Toyota MR2 SW20 and the HOLDEN VY II Commodore, as standard equipment.
[#] Jun 29, 2007 04:45pm
Reg'd: Feb 14, 2007
The Guru
Nice Web.
2 questions, I think you already answered one of them in another thread but cause I dont remember:
1) Which do you recommend getting first?
2) For our cars, can we only get strut bars for the front since our rear is double wishbone suspension and not Macpherson suspension?
[#] Jun 29, 2007 05:06pm
TeeCizzle
Reg'd: Jun 15, 2007
Chief Mechanic
I dunno if you'll listen to Me..I recommend...
Rear Sway Bar first....
Front Strut Bar not really needed..Looks Bad-A$$!!!
Front Sway bar?....I think our stock one is good enough!
The Rear Strut Brace...
[#] Jun 29, 2007 05:18pm
Reg'd: Apr 17, 2006
THE SHADOW
Mayo wrote:
Nice Web.
Sway bars do the most.....better recommendation but strut bars are good too.
No, the Ingalls bar is a rear strut bar and Greddy makes a traditional style strut bar for our car in the rear as well. I just didn't want anything in the trunk showing.
[#] Jun 29, 2007 06:21pm
Reg'd: Feb 14, 2007
The Guru
Man, Im confused. So we can get a strut bar for the rear? Even though its a double wishbone suspension?
[#] Jun 29, 2007 07:39pm
Reg'd: Dec 08, 2005
you can get a rear strut bar to be used in combination with a rear sway bar.
the sway bar by itself is effective and a strut bar increases the rigidity.
IMO the most effective first suspension upgrade would be a rear sway bar
[#] Jun 29, 2007 07:43pm
Reg'd: Dec 08, 2005
Yes
an alternative would be the rear strut brace...
Web's Rear Strut Brace Thread
[#] Jun 29, 2007 07:45pm
Aciidsneaker
Reg'd: Feb 24, 2007
Nice info see you took from SqMK's work site eh?
[#] Jun 29, 2007 08:00pm
TOP: Home > Performance Mods > Suspension & Brakes > Strut bars and Sway bars....what's the difference?
