Home > Performance Mods > Suspension & Brakes > Understanding Oversteer/Understeer and how to correct them
Reg'd: Apr 17, 2006
THE SHADOW
This was taken from http://securitydriver.com/aic/stories/article-124.html
Quote:
The phrase Under and Over Steer are used often in training to explain vehicle characteristics. Understeer and oversteer is a condition that describes what happens to a vehicle when you move the controls, specifically the steering wheel.
When you turn the steering wheel there is energy pushing on the Center of Gravity (CG) of your vehicle, and it makes no difference who you are, what you are driving, or where you are driving it, the laws of physics dictate that when you move the steering wheel, you create a force acting on the cg of the vehicle. The amount of energy (it can be measured in G's or in pounds) is determined by how much you move the steering wheel and how fast you're traveling. It's pretty simple, the more speed and the more steering the more energy pushing on the vehicle. Remember from high school science "for every action there is an opposite and equal reaction". So if there is a force pushing on the CG of your vehicle, there has to be an equal and opposite force pushing back - that force pushing back is created by the friction your tires make with the road.
If you drove around a corner or made an emergency maneuver that created 3200 lbs pushing on the CG of your vehicle - in the perfect world your tires would be pushing back 1600 lbs front and rear. This would be called neutral steering, and it is a characteristic seldom found in vehicles.
But what happens most often is that the vehicle will either oversteer or understeer. What follows below is a BASIC explanation of under over steer.
Understeer (the NASCAR guys call this "push") - in a turn, or emergency maneuver understeer is the condition where the front tires lose adhesion while the rear tires remain in contact with the pavement. The car tends to travel straight ahead, even though you are turning the wheel. In our example the front tires can only push back with 1000 lbs and the back tires push back with 1600 lbs.
You can't learn to correct under and over steer by reading a book or article etc. But I'll give it a shot, keeping in mind that this is as basic an explanation as you can get.
In an under steering condition turning the steering wheel more won't work and will aggravate the scenario. To fix it reduce speed and/or reduce the amount the steering wheel is turned. You can correct understeer by reducing throttle until the front tires regain adhesion.
Oversteer (NASCAR guys call this "loose") -- In a turn, or emergency maneuver oversteer is the condition where your rear tires lose adhesion while your front tires remain in contact with the pavement. The back end of your car tends to slide out. Turning the steering wheel more will makes things worse.
[b]Let me repeat - You can't learn to correct under and over steer by reading a book or article.
To fix oversteer reduce speed and turn the steering wheel in the opposite direction of the skid. In our example the rear tires can push back with only 1000 lbs and the fronts push back with 1600 lbs.
Correcting oversteer can be tricky and requires training and practice. Then there is something called power oversteer.
An example of power oversteer; you're in pursuit or for what ever reason driving fast around a corner - as you exit the corner you apply gas, and the back of the vehicle starts to swing out. The back of the vehicle is swinging out because you have applied too much gas and the back tires are loosing adhesion - to correct the problem you either have to steer less and give it less gas.
Also there is another form of oversteer that is called trailing throttle oversteer, which means that as you turn and take your foot off the gas the back of the car swings out. Trailing throttle oversteer is due to the back tires doing funky things when you transfer weight from the rear to the front. (very common in armored vehicles). Correct trailing-throttle oversteer by smoothly increasing the throttle (to transfer weight to the rear tires) and apply steering to counter the rotation.
What separates da mens from da boys, is a vehicle that goes quickly from understeer to oversteer, or vice versa. You hear it often when watching a NASCAR event; they will say that the car was tight entering the corner and loose coming out. This is something you got to learn to control.
I highlighted the important parts.
[#] May 11, 2007 10:05am
Reg'd: Jan 03, 2007
i understeer alot but i can control it. but a while back, some guy pulled out of nowhere and i had to get out of hte way, and i lost control of my front AND rear tires. then the front tires caught some grip and i was sliding all over the place lol
[#] May 11, 2007 10:15am
dsm3383
Reg'd: Mar 14, 2007
Just for everyones information....our car has oversteer. I did the Constant Radius Test on my Scion to observe this behavior.
This is the data I took during the test around a 100 ft diameter circle.
This is the plot. I plotted the steering angle from the tire and the steering wheel. As explained in the Constant Radius Method the plot of the parameters show if the line slopes downwards than it is oversteer and if it slopes upwards it is understeer. A straight line is neutral steer.
When I did this test and I reached the maximum velocity in which I could control the car around the circle I did feel the oversteer quite well. Thought this would be interesting for everyone.
-Ben Franklin
[#] May 11, 2007 10:27am
Reg'd: Apr 17, 2006
THE SHADOW
^Definately unexpected from a FWD, but our weight problem does make this make sense. With the heavy glass and hatch, seems like more of our weight is in the middle to rear, than middle to front.
Springs/Sways/Strut bars will helps A LOT!
[#] May 11, 2007 10:32am
dsm3383
Reg'd: Mar 14, 2007
Actually our ride weighs 2905 lbm. The weight distribution is 61% in the front and 39% in the back. So 1772 lbm in the front and 1132 lbm in the rear.
That article is a misconception with it all dealing with your center of gravity. There are alot of other factors in the charateristic of the cornering of the vehicle. The suspension set-up, steering operation, and tires also play a huge role in this. You can't just look at weight and the distribution of it on a vehicle and assume how its going to behave under cornering. Thats why Car and Driver performs the constant radius test when they test out cars.
-Ben Franklin
[#] May 11, 2007 10:42am
Reg'd: Apr 17, 2006
THE SHADOW
Do you have stock tires?
[#] May 11, 2007 10:44am
soCAL-tc
Reg'd: Oct 24, 2006
^great observation...
dsm3383
Reg'd: Mar 14, 2007
Yes, I have stock tires and it did effect my test. Like I could only go around the circle at 28 mph at the fastest due to the tires.
-Ben Franklin
[#] May 11, 2007 10:49am
Reg'd: Apr 17, 2006
THE SHADOW
Hmmmmmm..............you should get BFGoodrich g-force T/A KDW 2
Those are great ..........I have yet to hear my tires squeal on turns.
[#] May 11, 2007 10:51am
dsm3383
Reg'd: Mar 14, 2007
Web....already ahead of you on that!! When I get the money for my Gram Lights 57F they are going to be wrapped in the G-Force KDW 2 cause I heard the best things about them and like the price also.
-Ben Franklin
[#] May 11, 2007 10:57am
Reg'd: Apr 17, 2006
THE SHADOW
.......awesome!
[#] May 11, 2007 10:58am
dsm3383
Reg'd: Mar 14, 2007
Just a note for everyone. The above test and data I collected was on my stock 2007 Scion tC. So this is the cornering characteristic behavior at stock.
So, if you have added modifications to your suspension(springs, strut/sway bars) and tires then your car may behave differently. The constant radius method test would have to be done on your ride to fully find its behavior.
-Ben Franklin
[#] May 11, 2007 11:08am
Reg'd: May 03, 2005
El Chupacabra
LFB can correct understeer to a certain degree by transferring more weight to the front and providing more traction to the front wheels
Y s0 S3ri0uS?
[#] May 12, 2007 01:26am
de16
Reg'd: Feb 07, 2007
Chief Mechanic
dear god.... if any1 i repeat if any1 here reads this and has INEXPERIENCE with understeer/oversteer please do not try to go out to canyons or w/e and go all out..... correcting oversteer and understeer takes practice. An easy way to correct understeer usually is to tap on the brake. but with oversteer when you break loose. DO NOT TRY TO ATTEMPT to countersteer unless you know how much to countersteer. I mean eventually every1 will learn how to correct this but it takes experience and learning to know. If people are gonna practice doing hard turns or go all out in touge... be an experienced driver dont want anyone busting onto clubsciontc and crying "I CRASHED MY CAR INTO THE MOUNTAIN!" or... "I DROVE MY CAR OFF THE MOUNTAIN"
oh yeah btw. IF every1's reading the past post like what web said get better tires. please dont rely on tires. WEB i know has had a good exp for driving lol. but for every1 else. Heel toe, rev matching just help for braking faster. what else... Oh yeah a good technique that i've been trying to practice when i have the chance to help correct understeer is LFB just like Vicious pointed out, but doing that nvm if someone LFB you'll understand lol most likely gonna stall your car if you try LFB to any1 new on that lol.
[#] May 12, 2007 01:57am
Reg'd: May 03, 2005
El Chupacabra
Please do not practice these advanced techniques on public roads. I cannot stress that enough That's what auto-x is for! If you guys have never heard of auto-x or don't know what to expect then allow me to skool j00
Driving in an autocross unleashes all the adrenaline you've been saving up, and dealing with all that extra mental energy is a big task. It's easier to say "Relax" than it is to do it. One good way is to stay focused.
· The tendency is to treat straight-aways as if they were the front straight at SIR when in fact they are not. This means that the speed you carry through the corners is more important than how much you accelerate down the "straights". This furthermore means that you should use the straights to set up the corners, not as a series of connected drag races. You'll notice that the fastest cars don't seem to slow down as much in the corners.
· It helps to look backward as you walk the course. How you exit one corner often determines how well you'll be able to approach the next corner, and if you aren't set up right, you'll waste time.
· Smoothness is a key virtue. If you're burning your tires and sliding a lot (either under braking or acceleration) you're wasting time and energy. Smoothness also gives your suspension the most opportunity to keep the tires planted.
· Abrupt movements by the driver mean the suspension is spending more time in abrupt transitions, and transitional handling is something most street cars are not very good at.
· Try your best to memorize the course when you do the walk-around. Drivers can and do get lost, particularly when the course has you weave in and out of cones on a "straightaway".
· If you're running street tires, be sure to pump up the pressure at a gas station before you arrive. You should have at least 35 pounds of pressure and maybe even 40+. The added pressure minimizes sidewall flex which, for street tires, is a major cause of body roll, which you don't want.
· Make sure your engine fluid levels are up, and have enough gas in the tank that you won't get fuel starvation in corners. Same is true for oil levels; the oil gets thrown around a lot and you don't want to uncover the oil pump pickup.
I have heard and learned many important tips over the years. Sometimes I
wonder if you have to be ready for them...as if maybe I heard them
before, but I was not ready. What follows are various tips that made a
signifigant difference in my driving at the time I heard it.
1. As soon as you pass the start line, you are only losing time.
Minimize how much time you lose. It's not just going faster, it's
spending less time on the course.
2. The trick is to drive 10/10ths. A novice will drive 7/10ths and then
not realize that they went to 13/10ths. Learn the edge and drive it.
That may mean some cones get hit and you spin. It's what teaches you
where 10/10ths is.
3. There are fast parts and there are slow parts. Learn the difference.
4. Don't square off the corners and point and shoot drive. A lot of
corners are parts of smooth arcs you can make. It's faster to drive a
smooth arc than a short straight and two jerky turns.
5. Be aggressive in chicanes. Attack them, stay in front of the turns
and as straight as you can. Getting "behind" in a chicane is a bad
thing.
6. Doing this well means being smooth. Being smooth DOES NOT mean you
are slow. To drive the car smoothly may require controlled chaos in the
car. Fast hand and foot movements do not mean you are not smooth.
7. Know your line you intend on driving. Understand it. Look for it. If
you drive such that you are forcing yourself off that line, you made a
mistake and need to slow down. The line is everything, unless you are
wrong about where the line is...then you need to change your mind.
8. Look ahead to where you want to exit the turn. Adjust your speed into
the corner to make sure your car will be on the right spot when your
exit the corner.
9. It's better to corner under acceleration than braking. Brake earlier
and then get on the throttle as quick as you can.
10. The earlier throttle points will be faster. Give up the end of the
straight to make your corner exit faster. That speed coming out of the
corner will carry thru the whole straight following the corner.
11. Do not try to save runs. If you get screwed up, go off course or mow
down cones. This saves tires.
12. Understeer is often caused by going in to a corner too hot. To
reduce understeer, straighten out the steering and/or reduce throttle
input.
13. A lift or quick stab at the brakes can cause the front of the car to
weight and allow better turn in.
14. Alignments are important.
15. If you start going slower or are less succesful than you should be,
check the car. Sometimes things change and it's hard to notice.
16. Seat time is important.
17. Autocross deliberately. Try to drive deliberately. Not just
reacting...but control the steering and drive the line. Then do it
faster.
18. Don't worry about long lists of tips. Work on one or two things at
a time. Don't try to adjust everything, put in a new swaybar and struts,
try out Hoosiers, and decide to use left foot braking all in one
weekend. Make changes one at a time and see how they feel.
19. There are many ways to setup your car and your driving can
accomodate them. Spend more time on your driving than your car setup.
Human nature is that it's easier to point to your car, or the classing,
or maybe someone else is cheating, or they spent more. But the biggest
variable in autocrossing is still always the driver.
#1 – Don’t be intimidated by the “Sea of Cones”
Autocrossing is an automotive sport that is safe and educational. Courses are designed with safety in mind. Tech inspections help insure your car is up to the challenge. As the average autocross course is less than a minute long, and at speeds under 45 mph, a bit of common sense is all that's needed to make each run safe and competitive. Wear and tear to your car is negligible, particularly if it's well maintained in the first place. The first time thru the "sea of cones" is usually the most difficult run. But once you've crossed that hurdle, you'll find yourself learning a lot about your car and yourself. And if you're not careful, you may find yourself getting addicted (like so many of us…). If you have any questions, don't hesitate to ask any of the Autocross Committee members (or send an email). We'll be more than happy to try and answer them for you!
#2 – Memorizing the Course
Autocrossing is clearly a sport of driving skill, but it has a mental aspect to it as well. Whereas on a racetrack you must learn the “line” around the course, the pavement is always the same regardless of which day you are there. However, an autocross course will vary from event to event. And a very important element of the sport is being able to quickly memorize the course. Two primary tools at your disposal are the course map, and the course walk-thru. The course map will always be on display to help you identify the sequence of gates needed to complete an “on course” run. Some people will redraw it onto a separate piece of paper, to help remember the layout. Before each Heat, the course will also be open for walk-thru’s. These are key opportunities to learn the course. When you walk the course you should try to visualize it from your driving perspective. Some people will even “duck walk” parts of the course to get a clear visual imprint in their mind. Also, try to avoid walking at the back of a crowd. If you’re surrounded by people, you can’t see what the course will look like when you’re behind the wheel. And if possible, try to walk it more than once. Each time around will help you develop that memory needed to get your runs up to speed quickly. Also, take advantage of any “narrated” walk-thru’s that may be announced; an instructor will help you analyze the course in detail.
#3– Tire Pressure
Many autocrossers will set their tire pressures to that which will maximize the performance of their car. But what if you’re new to the sport? A useful bit of advice is to talk to someone that has a car similar to yours. Find out what tire pressures they prefer, and consider that a reasonable starting point. Most cars with modern tires will find that pressures slightly above OEM recommendations will give their car good handling. But keep in mind that many variables come into play, including vintage of the car, wheel size, tire size and tire brand. Advice from others can be a good starting point, but your own equipment and driving style will dictate which pressures are best for YOU. One trick I like to use is to observe how much the tire is “rolling over” following an autocross run. As your car approaches max cornering, the tires will be stressed, and will be leaning over a bit in response to cornering forces. Ideally, the tire should never roll over more than ½ inch below the shoulder between the sidewall and tread surface. If abrasion is greater down towards the sidewall, the tire is under inflated, and allows too much squirm and bend. If the abrasion appears to be upwards towards the tread, the tire may have too much air, which can cause the tread surface to bulge and reduce the contact patch with the pavement. The goal is to keep maximum contact between the tire and pavement. Some people like to use chalk or crayon to mark their tires to make the wear more evident.
#4 - Keep your expectations realistic
Many newcomers to autocrossing become frustrated when they can’t immediately post fast times. Even seasoned track drivers will sometimes find that autocrossing doesn’t immediately come naturally. Its very important to remember that you’re competing on a “track” that you’ve never seen or driven before. And that you only get a limited time to walk it once or twice. And you have to commit to memory a layout that may only appear obvious on the printed or drawn map of the course. It takes a fair amount of experience to learn to memorize the course quickly, and to then be able to apply your driving skills to the pavement. Memorizing the course is crucial. If you make mistakes, it drastically reduces your ability to improve with each successive run. The best thing you can do is drive slowly enough on the first run to complete an on-course run. Don’t worry about the time. As you complete more on-courses, the times will drop on their own. Mistakes take you off-course, or cause you to fumble enough that your memorization is adversely affected, will limit your ability to improve.
#5 - Don’t be afraid to ask questions
You will find that most autocrossers are happy to talk about the sport. Novices should try to find some, preferably in a car like their own, to talk about tire pressures, car setup, and driving technique. Walking the course together can be very beneficial to both of you. Another benefit of working with someone is that they can help watch your runs, to give you pointers or even identify where you may have gone off-course or hit a cone. In addition to gaining insight about driving the course, you may even make a new friend or two along the way.
#6 - Be aware of the rules
As our program is growing, we have more people competing together in the same class. Its very important that your car be classed in the appropriate class, based upon any modifications you may have made to your vehicle. Stock classes are very limited in terms of allowed changes. Prepared, Improved, and Modified classes allow progressively more tweaks. If you have any questions about your own car, or even a competitors, please feel free to ask the Tech Inspectors, or anyone else on the autocross committee. Rules and class allowances are always available at Autocross Rules.
#7 - Learn to use weight transfer to your advantage
As you drive your car through an autocross course, the car is always in contact with pavement via 4 small patches under your tires. As you corner, accelerate or brake, the weight of the car will be shifting among those 4 patches constantly. Keep in mind that in order to achieve maximum cornering, you need sufficient weight transferring to your front tires, so that the contact patches are larger, and will thereby provide you with more grip and cornering ability. If you enter a corner and let off the brakes too early, you’ll find that some of the weight will transfer back to the rear tire patches, and the front tires will start loosing grip and understeering into the turn. Trail braking is one method to keep weight on those front tires, so they’ll have more cornering capability. However, at the same time, if the rear tires get too light, then the car will be prone to oversteer as you go through the turn. The key is understanding the dynamics at play, and learning to recognize why your car is exhibiting one behavior versus another. The same weight transfer principles affect how your car will accelerate. If you’ve transferred a lot of weight to the front under braking, and then quickly stab the accelerator, there won’t be enough weight on the rear tires to generate traction and keep them from spinning. Modulating the transfer of weight between the front to the rear will enable you to more effectively apply power coming out of a turn.
#8 - Looking Ahead
In the movie classic, “Gumball Rally”, the Ferrari driver is fondly remembered for removing the rear view mirror from his windshield, while exclaiming “What is behind you, does not matter…..”. I guess in certain circumstances that may make sense. Instead, I want to talk a bit about the importance of what is in front of you during an autocross. As you have probably figured out by now, a significant element of autocrossing is the mental memorization that’s necessary, in addition to basic driving skills. While navigating the course, its very important that you’re aware of what is coming up next, in order for you to successfully setup your entry and exit of each corner. A popular driving concept is to be looking further ahead down course, rather than focusing on each gate as you drive through it. It’s a skill that many of us are probably already subconsciously using to some degree, though it may not be apparent. Basically, it involves focusing your vision at the “next” course element up ahead, such as braking zone, apex, etc., while using your lower peripheral vision to manage what is happening immediately in front of you and your car. You’ll find it amazing how much information you can actually process in the field of view immediately below your center of focus. What happens is that you are now navigating the cones closest to your car with your peripheral vision, while your primary focus is helping you set up the proper line towards the next course element. As you navigate towards the next element with better planning in mind, you’ll find that the cones coming at the nose of your car are where they should be, and navigating them with your peripheral vision feels natural rather than a crisis. If instead your focus is only at each gate coming up, you’ll find it more difficult to manage a smooth line through a series of gates, and will instead be making choppy turns and constantly trying to correct your line as you decide to look at each successive gate. By combining your memorization of the course with the skill of looking ahead, you can drive the “line” through various series of connected gates, rather than one gate at a time. You’ll find your driving becomes more efficient, and your times will drop.
Y s0 S3ri0uS?
[#] May 12, 2007 05:36am
Reg'd: May 03, 2005
El Chupacabra
And:
Autocrossing Tips
By Dick Rasmussen
Chapman Report - March 1989
[GGLC member Dick Rasmussen is a two time SCCA Solo II National Championship (one of which was in a near stock Twin Cam Europa, his current autocross car, in class A-Street Prepared, a class allowing for very well prepared Porsches) plus he won too numerous local, regional, state, divisional, and Pro Solo championships to list. Auto-X Magazine did a feature story on the author and his autocross career. This begins a three part series by Dick sharing his thoughts on autocrossing. However, it should be noted that Dick's ideas and practices apply to not only autocrossing, but road racing, vintage racing and even street driving.]
The sport of autocrossing is enjoying a surge in popularity unprecedented in its history. It is becoming "Big Time" as evidenced by a magazine for the sport, books and videos on how to drive faster, tire company semi's at events, tires designed specifically for autocrossing, commercial autocross driving schools, a professional series, lots of sponsorship and contingency money, and a recent National Championship event at which the total value of the cars for ONE street legal stock class approached ONE MILLION DOLLARS! Even a major DRAG RACING magazine has done an excellent article about autocrossing.
Autocrossing has become more complicated than it used to be and the level of competition has gotten so intense that it is very easy for new autocrossers to become overwhelmed by all the things they need to learn. The purpose of this article is to summarize much of what is covered in more detail in other places and to pass on some of the lessons I've learned (many the hard way) in over 12 years of serious autocrossing. Topics include practice, driving techniques and car preparation.
Autocrossing is a chance for people who enjoy driving to drive at or near a car's limit with little risk to their bodies or their finances. In addition it can be a competitive outlet and/or a chance to develop and show off driving skills and technical abilities. In other words, it is a sport and a hobby for the majority of participants and therefore should be FUN!
A quick second gear slalom or a series of offset gates which allows a skilled driver to make a car literally "dance" can be exhilarating, as can the thrill of learning how to catch an impending spin in a sweeper by applying more gas and a little counter steering. Knowing how to get on the power after a corner sooner than anyone else is very satisfying and can help win championships.
Most of the suggestions in this series are directed towards making it easier to drive fast enough to get a thrill and to feel good about how well you did while reducing the number of frustrating mistakes which detract from having fun.
The most important element in autocrossing is the driver! Therefore, let's start with driving tips.
During a Tracktime Driving School at Charlotte Motor Speedway, IMSA racer Amos Johnson was asked how he knew he could safely drive an unfamiliar stock sports car through the high banked NASCAR turns 3 and 4 so "fast". Amos replied, "It never occurred to me I couldn't." Amos could say this because his experience allows him to almost instinctively determine a car's limits and he knows he can recover from reasonable excursions beyond the limits.
To become consistently competitive against tough competition you too must instinctively drive very close to the limit and must be able to quickly and neatly recover if you overestimate the limit.
The only way to develop and maintain the needed skills is through practice. The following are some ideas that have worked for me which make practice more effective.
Practice includes three important aspects. One is pushing the car harder and harder under controlled conditions until you bring your limits up to the car's limits. Call this "calibrating the seat of your pants".
Second is repeatedly driving at or slightly above those limits so you get very used to what they are and how to recover from exceeding them. This repetition gives you the ability and confidence to "easily" drive near the limits in competition. The third is trying different driving techniques to see which work the best. This does not include trying changes to the car. Experimenting with the car setup is "testing".
Begin by identifying the elements to practice such as slaloms, sweepers, braking, and shifting. Next find a place to work on one element at a time. Fortunately most autocross elements require very little space and speed and can, therefore, be done on weekends in empty industrial/office building parking lots with very little risk to your license or your car and, if you are careful, NO risk to other people.
As you begin practicing, GRADUALLY but steadily push the limits as you know them. Remember that until you get the tires sliding or spinning you haven't reached their limit. Once you finally exceed the limit, practice recovering. Keep in mind, however, that in autocross competition you DO NOT want to exceed the limit on purpose except in rare circumstances. What you are trying to do is find the limit and learn how to deal with inadvertently exceeding it.
When experimenting with technique, time the different techniques so you really know which worked better. A G-Analyst is probably ideal, but a stop watch is OK too. Try different lines. See how close you can get to pylons. When driving on wet roads with little traffic, try looking at your tire tracks in the rear view mirror. With practice, you can learn to put the tracks, and therefore your tires very close to lane lines, the shoulder, or any other reference mark on the pavement. Knowing where your tires are can save a lot of pylon penalties! In transient (very rapid change of direction) situations, such as slaloms and offset gates, get a feel for how the car feels just before you lose it so that in competition you can slow slightly before it's too late. Try using different gears in borderline speed ranges. See how the car handles in first gear versus second gear in a slalom. Determine whether you can use the extra power the lower gear gives you. See how much speed you really gain from accelerating for a few car lengths in a higher gear versus staying in a lower one and easing off the gas to stay at the engine redline. Every shift takes time and distracts from important aspects of driving at the limit. Each shift also increases the chance of making a mistake. Therefore, you only want to shift if the benefit is worth the cost and the risk.
Even though you are practicing, not testing, be aware of changes in the car, the pavement, and your driving which can be affecting times. It is important that you know what really caused each difference. Be analytical, be calm, take notes, and above all, be honest with yourself. Convincing yourself that you've found the fastest way when you haven't won't win autocrosses.
Well focused and executed practice really can make a difference. Before my first Nationals the published course map made it clear there would be "problems" I had never encountered. To prepare, I found places to simulate the problems and practiced and experimented extensively. What I learned made the difference between winning and losing. It can for you too.
"THE LINE"
The correct line is essential to getting the best possible run time and can easily make a difference of several seconds on a long course with many corners.
Driving the correct line involves more than placing the car on the correct portion of the pavement. It requires being able to do so while driving the car at or near its cornering, braking and acceleration limits despite unfamiliar course designs, pavement conditions, and car handling characteristics.
In autocrossing, essentially all corners including slaloms should be driven with a "late apex" line as shown in the drawings. As you pass the apex, you should already be as close to full throttle as the course will allow. The other types of cornering lines used in road racing rarely if ever are appropriate for the tight confines of autocross courses because they either result in a high number of time consuming mistakes or they are slower.
A major reason for using a late apex line is that it results in far fewer mistakes than does the use of early apexes. This is true on all courses but is much more apparent on relatively tight courses with lots of slow, tight turns. Many drivers make the time consuming and pylon eating mistakes which are guaranteed to result from not using late apexes in tight corners. Drivers will clip a cone with the car's inside rear tire because of entering too close to the inside of the corner (early apex) and then will have to creep around the rest of the corner before finally getting the car pointed down the next straight. In many instances the car may also hit pylons with the outside front tire or bumper because the driver's line and/or speed simply do not leave enough room to make the turn.
Because even the most open autocross courses are extremely tight compared to any race track, in many instances the exit of one corner is the entrance to the following one. With no straight in between there is no chance to move from the "wrong" side of the course to the "right" side before the next corner. It is extremely important in autocrossing to give up a little exit speed from one corner, if necessary, to allow the proper line for the next corner. A late apex line permits this approach while an early apex line is likely to prevent it. It is very common to watch drivers get in more and more trouble as they progress through a course because they either cannot or will not move to the correct line.
Even if an early apex line is somehow executed with no mistakes, for most cars a properly driven late apex line seems to be faster. After years of watching many National Champion caliber drivers from close range I cannot recall anyone who commonly used an early apex.
In order to drive a late apex line, you must slow the car down in time to turn at the proper place. Even for the most skillful autocrossers, picking the latest possible braking point is extremely difficult because we do not get to practice on the course. I have found that being conservative and braking a little earlier than may be necessary adds much less to a run time than does braking a little too late. It also allows some "cushion" in case traction is less than expected or speed is still too high. When in doubt, brake early and if you determine it was too early, try a slightly later braking point on the next run.
If downshifting is necessary for a corner the shift should be finished, with the clutch back out, BEFORE beginning to turn. Very few people can corner at the car's limit while steering with one hand. Even fewer can shift instantaneously. Shifting while braking will result in fewer "errors" than shifting while cornering. Even more important it allows you to already be applying power when you pass the apex which means you can start accelerating much sooner. Most cars also handle better and give the driver more control while accelerating than while coasting or braking.
Finally, it is extremely important that while walking the course you plan the line you intend to use because once you start driving it will be too late to figure out the correct line and how to actually get the car on it. Not only must you memorize the course, you must decide exactly where the correct line is through all portions of the course. You must also decide approximately where to brake and where to shift. This can be very hard to do when you also want to socialize with your friends but it is essential! Try to limit the socializing to one walk through lap and then get serious for two or three other laps.
The line and techniques described here may conflict with those suggested by other writers. However, they have worked extremely well for many successful autocrossers so whether you are struggling to become reasonably competitive or are trying to find the edge to allow you to win, I recommend that you try these techniques to see if they can work for you.
THE CAR
To quote a recent Yokohama Tire "Famous Amos" ad, "A driver is only as good as his car." So far in Autocrossing Tips I have been concentrating on getting drivers as good as their cars. This is because even though a slow driver may go faster in a faster car, he really cannot determine how to properly set up a car to go faster unless he is driving very close to the car's limit and knows what it is doing at the limit. Now it is time to cover some ideas on how to make the car as good as its driver has hopefully become.
Unfortunately for people who are not technically inclined, car preparation and improvement is a very technical subject. There are some very good, very thick, very complicated books available about car preparation which I have read many times and still don't fully understand even though I'm an engineer. Fortunately autocrossing in stock classes does not require much more than a good feel for what the car is doing right or wrong and a knowledge of some basic principles of what to do to correct problems. If you want to compete successfully in the other classes, you'd better either learn the technical stuff, get excellent advice, or hire someone who knows how to set the car up for you.
This article is not intended to cover major changes such as different springs and sway bars, engine modifications, etc. I'll leave that to the books noted above. It does cover some basic principles of autocrossing preparation which I've picked up over the years.
Preparation starts with making sure the car is running right, the throttle opens all the way, the fuel and air filters are clean, there is enough fuel, oil and water, and the engine pulls smoothly through its normal rev range. You should use a stopwatch to measure and record benchmark acceleration times for various rpm and/or speed ranges so that as the car gets older or you make changes you have a reference for comparison. This is especially useful to reassure yourself just before a big event that the car is still healthy.
Once the car is running properly, tires are the next most important part of car preparation for autocrossing just like they are for all other forms of "racing". If at all possible, anyone running street tires on a car that sees significant street use should have an extra set of wheels for tires which have been proven successful at the SCCA Solo II Nationals. In race tire classes, fresh rubber is as important for autocrossing as it is for racing. Used race tires may be cheap but they are not the way to find out how good you are. In the rain all but the very lightest cars are better off on their best dry competition tires than on deep tread lower performance tires.
Test the brakes to make sure they are not pulling or locking up one or more tires. If brake balance is off, there are many ways to adjust it (see the "books"). In stock you can try different brands and "hardnesses" of brake linings and pads. Remember to stay with street compounds since race compounds need to be warmed up too much before working to be useful for autocrossing or street driving.
Check the general condition of the suspension and make sure nothing is broken or loose and that all bushings are in good shape.
Watch out with shock absorbers. It is fairly easy to get the front shocks too stiff creating "understeer" or the rears too stiff causing "oversteer" or excessive "wheelspin". However, some front wheel drive cars seem to work with very stiff rear shocks. Since shocks are expensive and frequently hard to install, I recommend thorough research prior to purchase.
Make sure the front suspension alignment is appropriate for your type of car. Most street tires like as much negative camber and positive caster as the rules will allow in stock and street prepared classes. Exceptions may be very wide low profile tires on cars with excellent suspensions such as late model Corvettes, IROC Camaros, and Trans Ams.
The experts are recommending one-sixteenth to one-eighth inch toe-out these days for cars which normally run toe-in. I haven't done any testing to compare different settings. However, my guess is that it is much more important on a car like a Mustang V8 which keeps a lot of weight on the inside front tire in a tight corner than it is on a mid- or rear-engine car which picks up the inside front tire in tight turns.
Be careful with toe-out on the street since it may cause instability at highway (or above) speeds. If you figure out how many turns of the tie rods it takes to switch between street and autocross settings you can adjust toe easily without alignment equipment.
Some independent rear suspensions have adjustable alignment. More negative camber is probably a good idea since it will help cornering but be careful because you may create too much wheelspin in a rear wheel drive car. Be very careful with rear toe unless you really know what you are doing. The books say (I have not tried it) that rear toe-out is very unstable.
Many autocrossers over-emphasize the importance of minor changes in street tire pressures and fool themselves into thinking they can feel a couple of pounds difference. Start with what the tire company or a fast competitor in a similar car recommends. Then check to be sure the tires are rolling all the way to the edge of the tread but not onto the sidewalls. If they aren't rolling under far enough, don't lower the pressures, drive harder! If they are rolling too far, try more air. In some cars you will not be able to completely avoid sidewall scuff.
Unless your car is grossly underpowered in a class where it is legal to make major horsepower improvements, power is not as important as traction and handling. Responsiveness (i.e., not bogging or stumbling) and the flexibility to minimize the need for shifting are much more important.
Since we get little or no chance to make more than minor changes at an event, the car should be set up for an "average" course. If possible, a car should not require "tossing" or "pitching" into a corner. Even if you are the extremely rare driver who can toss a car well consistently, there are too many corners on most autocrosses where it simply cannot be done. Conversely, the car should not spin at the slightest provocation. Such cars never let you feel confident. Plus if they are rear wheel drive they probably have too much wheelspin.
Different driving styles and ability levels can result in understeer for one driver and oversteer for another in the same car. Keep in mind that as you get faster or experiment with different lines your perception of the car's handling balance will probably change.
Whenever you make a change to the car, you must test it. Make one change at a time and make sure any performance difference is a result of the change and not some other factor such as tires, dirty course, driver error, etc. Remember that modifications do not necessarily help, despite what "everybody" says or assumes. Any professional racer can give plenty of examples of mods which either had no effect or slowed the car. Watch out for setups which only work if you don't make any mistakes.
Perfect runs are very hard to come by in autocrossing. A slightly slower, more forgiving setup will give you the confidence to drive closer to the limit than one which "bites" if you overdrive slightly.
One of the most critical aspects of car setup in any sort of racing is finding the optimum balance between corner exit understeer and corner exit oversteer. Too much of either ruins lap times. Try to find the combination of car setup, driving style and cornering line which allows you to brake hard, turn the corner, and then get to full throttle as soon as possible without making mistakes you cannot easily correct.
In my opinion, corner exit is the single most important factor separating consistent winners from the rest of the pack. Given otherwise equal cars and drivers, the driver who gets to full throttle first will win!
This article is the last of the series. I hope this helps make autocrossing fun for you. Remember that this is only a summary and doesn't cover everything you need to know to make you and your car as fast as possible. If you want to win against tough competition, you'd better plan on learning much more than these articles have covered. Besides, you don't think I'd give away ALL my secrets, do you? I STILL WANT TO WIN!
by
Glen Region, SCCA
Painted Post, New York
© May, 1996
revised, March, 1998
With thanks to:
Karl Hughes (Finger Lakes Region) for his novice help sheets;
Josh Sirota (San Francisco Region) and Andy Hollis (Houston Region) for course-walking and driving tips;
Christine Johnson (Houston Region) for enthusiastically sharing her novice program ideas;
Team.Netters - Paul Brown, Sid deLeon, Frank Freda, Stuart Galt, Dan Hollenbaugh,
Eric Jones, Mark Sirota, and Jim White - for many helpful ideas which are used in this book;
and Paul Schelling (Glen Region) for patiently proofing.
What is Solo II?
"Solo II is a precision sport, much like, say, archery, riflery or golf. You must be precise and consistent, all the while driving so fast you can barely concentrate" -- Mark Sirota
Solo II events (also known as autocrosses) are an all forward motion driving skill contest. Each driver is individually timed to the thousandth of a second, over a short, miniature road course clearly defined using traffic cones. Cars compete one at a time, hence the name "Solo", in a class with similar cars. An event can be held on any flat paved surface, usually a parking lot, or airport apron or runway.
Solo II emphasizes driver skill and vehicle handling rather than just speed. The corners are tight, and there are lots of them, so the driving is exciting and challenging. Solo II speeds do not exceed those normally encountered in highway driving. (This is the main difference between Solo II and Solo I; where much higher speeds are attained)
The skills you learn and practice here; smooth transitions, enhanced braking, and skid correction, will have an immediate impact on improving the safety and skill of your street driving. Solo II is an excellent way to teach car control to young drivers in a safe environment.
Solo II is also a very social sport, filled with some of the friendliest people you'll ever meet. The camaraderie of the drivers is a special part of autocrossing that is profoundly satisfying.
Cars are divided into categories and classes. Classes separate cars by performance, so that VW Rabbits compete against Honda Civics, and Porsche 911s compete against Nissan 300ZX Turbos. Categories separate cars according to their level of preparation. Unmodified cars compete in classes in the Stock category. Cars with modifications to the suspension, intake or exhaust system, or different wheels and tires compete in Street Prepared. Cars with engine modifications and race cars compete in the Prepared category. Cars with different engines, and open-wheel cars compete in classes in the Modified category. The complete descriptions of classes and preparation allowances are spelled out in the Solo II rule book.
The costs of Solo II competition are reasonable because you can compete in anything from a real race car to the car you drive on the street every day. Entry fees are usually $15 to $20 per driver, and two drivers can share a car.
Sports Car Club of America (SCCA) sanctioned events are insured through the SCCA, and are conducted under the watchful eyes of SCCA Safety Stewards. The rules and guidelines established by the SCCA and enforced by the Safety Stewards are what makes this one of the safest motorsports. A day of autocrossing is far safer for both car and driver than most people's daily commute to work.
Approximately 1100 SCCA sanctioned Solo II events, totaling more than 10,000 competitors, are held each year throughout the country. More people compete in Solo competition than any other motorsport save drag racing.
With so many SCCA regions, rules and programs may differ somewhat between the regions. For instance, some regions have an extra class for their national-caliber drivers, some regions drive in morning and afternoon heats. A quick look at a region's supplemental regulations will outline local customs. In this handbook I will indicate with RLS (Read Local Supplementals) those topics which are covered in your local "supps".
On Being a Novice
You'll remember your first event for a long time. The adrenaline that makes you shake at the start-line before your first run, and the even bigger surge of adrenaline you feel when you finish. That excitement is part of the sport, and it's why we all do this.
Don't let being a novice overwhelm you! Every driver, including the National Champions, had a first day and a novice season. Autocrossing is a skill that requires instruction and practice to see improvements. If it was easy, it wouldn't be so competitive, or so fun. In fact, when experienced road racers come to Solo for the first time, we often put them in Novice Class. It's not like falling off a log for them, either. The great thing about this sport, though, is that even when you're going "slow", it's still fun driving.
The course may seem "busy" at first, because it's tighter than what you see on the street, and you're trying to attack it faster than you could in traffic. You'll have fun learning the sport and learning to keep the car in control as you get faster and better with more seat-time.
With that said, here are some tips to give you the right novice attitude, so you don't become discouraged:
Your goal is to have fun! That's why everyone is here.
Your goal for the first run is to avoid getting lost on course (see course-walking tips)
Your goal for the rest of the day is to improve your time on each run
Your goal for the second event is the same as the first.
Your goal for the rest of the season is to beat somebody (anybody!) and continue to make each run faster than the last.
At this point, you are learning a lot on each run, and you may be 10 seconds behind the class leader. That's not unusual! You're still doing OK.
Generally speaking, the veteran drivers like to help the novices. The magic words "I am a novice" will get you extra instruction from other competitors, who can critique your run. Just be careful not to interrupt a driver on a course walk, or while he or she is concentrating on going over the course in his or her head. (See the section on Solo Etiquette.)
Don't forget, there is a Novice Class Instructor available to answer your questions and help you get started.
Description of the Novice Program
The Novice Program was created to help people new to autocross have fun from the first event. If this is a new sport for you, you will have lots of questions. The Novice Chief, the instructors, and the novice handbook are here to answer them, and to show you some of the basic skills to get you started (RLS).
The Novice Class is designed to let all novices compete against each other, regardless of their car or preparation level. The PAX index is used to handicap the different classes and categories based on average performance nationwide. (more detail on the index in a later chapter)
Eligibility for Novice Class (RLS)
Request novice classification at registration and it will be noted on your form. You must request this before the first car is run. Novices display an N after the class markings on the car, such as ESN or DSPN, etc.
When Novices make their runs (RLS)
Novice class drivers compete only against each other, scored by PAX indexing. Trophies are awarded for the Novice Class by the same system used for the open classes; the top third of the class.
Most importantly, remember this is a Novice Program, a whole package for instruction and fun. It includes instructors, the handbook, a guided course-walk and rides with experienced drivers. We want to answer all of your questions and help you have fun. Please take advantage of us.
What to Bring to an Event
This list covers everything from sunscreen to snacks to tires pressure gauges. You will probably come up with your own list of things you need at a Solo event, but this will get you started.
You must have:
Your car (although you may share a car with someone else) Your entry fee A valid driver's license
You may want to bring:
Your SCCA membership card, to get a discount on entry fees
A safety helmet
Extra air in your tires. Stop at a gas station and fill your tires to approximately 45psi-Front/35psi-Rear for a front-wheel-drive car, or 40psi all around for a rear-wheel-drive car.
Suitable shoes for driving. The best are light-soled, with a narrow sole which does not stick out past the side of the shoe
Sunglasses
Sunscreen
Clothes appropriate for the weather forecast, plus a change for when the forecast is wrong.
Rain gear / umbrella
A hat
A folding chair
Thermos of water or other non alcoholic beverage
Cooler for lunch or snacks
Windex and paper towels
A pad and pencil to write down all the advice you'll get
A copy of the current SCCA Solo II Rule Book
A good tire pressure gauge
A portable air tank or compressor
Chalk or white shoe polish to mark the tires
What Happens at a Solo
People begin arriving before registration opens (RLS) so they can unpack their car, change tires and get ready for the day before registration begins. It is best to arrive at or before the beginning of registration so you will have time to register, tech your car, walk the course, and have ample time to talk to the Novice Chief.
Registration
To register you must have a valid driver's license and entry fee (usually $15 to $20). Fill out the information card at the registration area. They will help choose the class for your car if you don't know what it is. You will also be assigned a car number for the day. At registration, you will be asked to sign the insurance waiver. You must do this to compete, and any guests you bring must sign the waiver also.
Once you know your class and car number, mark your car using white shoe polish on the window (it comes off with Windex), tape paper numbers inside the window, or use magnetic numbers if you have them.
Tech Inspection
Your car must pass tech inspection before you can compete. Read the tech inspection chapter to see what you'll need to do. Registration may be at one central area, or at your "pit" space (RLS).
The tech inspector will sign your card if you pass, or recommend changes to make the car pass, such as additional tie-downs for the battery or removal of loose items or hub caps if you've forgotten.
Course Walking
After tech, you will have time to walk the course. Before you go, read the chapter on course-walking tips. Course maps are available at registration, and the Novice chief will take you on a guided walk after the drivers' meeting. Try to have the course memorized before you go on the guided walk.
Drivers' Meeting
The drivers' meeting is mandatory for all drivers. The event chair will hold the meeting approximately one half hour before the first car starts. Be sure to attend. This is where you will find out information you'll need to know about the course conditions, number of runs, particular safety concerns, how penalties are assessed, and how work assignments will be handled.
At the end of the drivers' meeting, the Novice Chief will announce the novice course-walk.
Your Runs
You will have a minimum of three timed runs, weather permitting. Depending on the event, you may get as many as five timed runs. Find out who is running before you and after you, so you know when to line up (RLS). Running in order makes the timing people's job easier, and keeps the event running smoothly, but if someone gets in front of you, or you are running a little behind, don't worry too much about it. The event chair will call out which classes are to come to the grid (line of 4-5 cars waiting to run)
Once you are in grid, you will wait for the cars in front of you to launch, and you will move up until you are on the start line. A starter will wave a green flag when it is OK for you to start. The green flag means go as soon as you are ready, the timer will not start until you pass through the lights. Don't take too long if we are running two cars on course at once, because you start is timed to make sure you do not get too near the car already on course.
If you do get "lost" on course, take the time to orient yourself and continue. Don't head back to the start line, because you may be pointed toward another car. Just take the time to get back on course, and continue the run as a practice! If the next driver catches up, they will be red-flagged and be granted a re-run (which they'll use to its fullest potential).
Times are posted after each run. Your fastest run of the day is used to determine your finishing position.
Read the Driving Tips section for more detail about your runs.
Your Work Assignments
It's best to report for your work assignment as quickly as possible when it is time for you to work (RLS). Otherwise, some people end up working longer than others, which is no fun. The place to get work assignments will be announced in the drivers' meeting.
We try to put a novice with an experienced driver on a station if we have enough people. For a little bonus instruction, ask your co-worker to talk about the techniques of the cars on course. Read the chapter on Working to get more detail on how to call in cones and stay safe while working the course.
Fun Runs
If time permits, fun runs are held at the completion of the event while trophies are being readied. This is your opportunity to ride with other drivers and have them ride with you. Fun runs usually cost one to two dollars.
Course Clean-up
Once all the timed runs and fun runs, if any, are complete, everyone helps clean up the course. This involves bringing in the fire extinguishers and flags, cones and timing equipment, and storing them in the trailer. Scoreboards need to be cleaned off and the pit area needs to be checked for trash. When everyone helps, this can be completed in fifteen to twenty minutes.
The Awards
After the event, following course clean-up, everyone meets for the trophy presentation. The location for the presentation is usually announced at the drivers' meeting. The event chair and his/her assistants will give out results and present trophies to the top third of each class, plus a trophy for Fastest Time of the Day (FTD) and the PAX challenge winner; the driver with the fastest indexed time.
Tech Inspection Requirements
Safety Helmet: If you bring your own safety helmet, it must be approved by Snell in the current or two most recent ratings (e.g. if Snell 95 is in production then that, 90 and 85 are legal). The club provides loaner helmets for people who do not have one.
Safety Belts: Original safety belts, at a minimum are required. Shoulder belts are not required, if your car did not come with them, but you must have a lap belt. Belts must be firmly attached.
Solidly Mounted Battery: The battery must be held down properly. If it can be moved at all, it will not pass. There are some additional battery requirements which may affect you if you have modified your car. The Tech Inspector will help you out with them.
Legal Tires: In Stock and Street Prepared categories, the tires must have measurable tread, and must be in good condition. Excessive weather checks or visible cord/plies will fail inspection. Tire pressures should be higher than used for the street, usually 45psi-Front/35psi-Rear for a front-wheel-drive car, or 40psi all around for a rear-wheel-drive car.
Brakes: The brake pedal must be firm, with no loss of pressure when held down.
Steering / Suspension: The steering must be tight, with no excessive play. Wheel bearings cannot have excessive play.
Hub Caps and Trim Rings: Hub caps, trim rings and wheel covers must be removed for competition, unless they are bolted to the wheel.
Loose Items in Car: All loose items must be removed from the passenger compartment and trunk. This includes the floor-mats. You may remove the spare tire and jack, but you are not required to if they are properly secured.
Fluid Leaks: Excessive fluid leaks will not pass inspection.
Numbers and Class Markings: The car numbers and class markings should be prominently displayed on both sides of the car in colors that contrast with the paint, and should be large enough to be seen easily from the timing van. White shoe polish for marking windows (comes off with Windex ) is available for people who don't have magnetic or paper numbers.
Adequate Muffler: Your car must be quieter than 95dbA (RLS) measured 50 feet from the course at a place where you are under full throttle. Due to the possibility of losing sites for noise problems, this rule is strictly enforced. (If your car is quiet enough to avoid attracting Police attention, it will most likely pass the noise requirement)
Throttle: Accelerator pedal must have a return spring and operate freely.
(RLS) for local tech requirements
You are not required to have your car registered for street use, but it must pass tech inspection.
Working Rules and Safety
Do's
Report to work promptly.
Make sure your station has adequate supplies; extra pylons, fire extinguisher, radio and red flag.
Know your area of responsibility and station number.
Make sure cones are in their proper place when you get to your station, and check them periodically during your shift.
Understand the pylon rules (Section 7.9 A, B &C in the rule book) e.g., pointer cones do not count if hit (see below), and a car is off-course (DNF for Did Not Finish) if they pass on the wrong side of a cone.
Pay attention to cars on course for accurate cone counts and your safety. It is best to watch the back of the car and the cones themselves to see the wobbling cone which may have left the box.
Replace cones as soon as possible, another car will be coming through in as soon as 30 seconds.
Be prepared for exposure to sun/rain, wind, heat/cold while on station
Keep red flag in your hand, unfurled (but not flapping) ready for immediate deployment.
Stay alert for unexpected pedestrians and vehicles
Don'ts
Do not use cameras while on station.
Do not sit down and do not wander away from your post.
Do not turn your back on cars on course. Safety First!
Do not red flag a car unless instructed to do so by the radio person or if it is an emergency. However, if in doubt, err on the side of safety!
Do not litter
Do not pick up hot parts dropped on course because of risk of burns.
A penalty is given if :
If the cone is knocked over and is out of the box.
If the cone is knocked over and is in the box.
If the cone remains standing but is out of the box.
A penalty is NOT given if :
The cone remains standing is touching the box
The cone remains standing and is partially in the box.
And of course, if the cone remains standing within the box.
Car set-up Tips
Keeping things inexpensive, we'll only talk about things you can do for free, or under $50. After a while, you may want to put more go-fast goodies on your car, but make sure to read the rule book, and stay legal for your category.
But also keep in mind, at this point you can go faster sooner by working on the driver instead of the car. See the course-walking and driving tips!
What you can do Today
Tires: You've already read that you should put an extra 10 to 15 psi in your tires. The reason for this is to keep your tires from rolling under during hard cornering. But how much is too much? Put chalk on the edges of your tire, in three places around the diameter, and you can see how far over the tire was going during your runs. Bleed out a little if the chalk is still showing on the tread, or add a little more if the chalk has been worn off down the sidewall. The line of worn chalk to remaining chalk should be right at the corner of the tread and sidewall. Keep notes on how many psi you ran, and where the chalk line was, for your next event.
Remember that as you get better and corner harder, you'll need more air to compensate, so keep using the chalk at every event.
Driver Restraint: In order to have good control in driving, you, the driver, have got to stay put. So make sure your seat belt is tight and firm. Some people like to tug hard (fast) on the shoulder strap to engage the lock on the reel.
Driver Location: Most experienced drivers will agree that the best place for your seat - to give you the best control - is seat forward far enough to have your leg slightly bent when the clutch is all the way to the floor, and seat-back reclined or upright to a position that allows you to rest your wrists on the steering wheel when you shoulders are firmly against the seat.
This position allows you to run the full range of steering inputs and foot motion without stretching or moving in your seat, and can have a huge impact on your driving skill.
What you can do before the next event
Alignments cost $20 to $60, and if you're looking for a cheap way to improve your solo II set-up, this is a good one.
Some words of caution, first. Manufacturers set their alignments to what they consider to be the most predictable and stable settings. Improving your car's turn-in for autocross may make your car twitchy on the street. So use your own discretion. To get some suggestions, though, ask a driver who has a car similar to yours in weight, wheelbase or front or rear wheel drive.
Course Walking Tips
"You must be able to keep track of the course in your head. If you can't, then you can't drive it to its fullest potential"
Josh Sirota
That quote is worth five seconds to a novice. Knowing how to walk the course is the most important step in being competitive and staying "ahead" of the course. Usually, you'll want to walk the course at least three times.
Step 1) Walk the course. Your first walk will be to get the general layout, and is often a social walk. Now get away from friends and walk the course alone, concentrating on memorizing the layout. Think of it in sections, with key cones marking the turns, such as:
start straight
slalom (enter on right)
decreasing sweeper to the left
"little snake" then "big snake"
right-hand curve (look for three pointers)
"thread the needle section"
tight right, then tight left
finish
Stop every now and then and run through the course in your head, from the beginning to where you are. Get down - the course looks different from a seated position. This will give you a better picture of what the course will look like at speed.
Pace off the distance between cones in a slalom. Some course designers vary the distance, and it's good to know before you arrive whether you will have to vary your speed in a slalom. Take a note-pad if you like, and make notes such as pavement changes, camber change, bumps, sand, etc.
Make a mental note to yourself (or write it down) how far ahead you will be looking. When I walk the course, I say to myself, "OK, when I am here I will be looking there" This will help you to remember to look ahead while you are driving.
"Repeat this step over and over until the picture is perfect."
Andy Hollis - Four-time Pro Solo and Solo II National Champ
How do you know if the picture is perfect? Sit down by your car and try to draw the course on a blank piece of paper. Include the key cones you want to recognize while you drive. If you can't draw the course, you will want to walk it again. Once you leave the start line in your car, you should not be spending any time figuring out where the course is.
Step 2) Plan the course. (Do this while walking the course again) Now decide exactly how you want to drive the course. Driving the course perfectly involves two things; coming up with the correct plan, and executing the plan correctly. If you don't have a plan, you can't possibly know where you didn't execute it correctly. It's hard to know if you did this step correctly, but step 4 is something you can work on.
The plan involves the line you will take through the cones - the quickest way through. Note, I didn't say shortest. Think about the characteristics of your car; does it corner better than it accelerates, or the other way around? That will tell you whether to slow down so you can get through the corner in control and get on the throttle as soon as possible, or try to carry speed through to keep up the revs.
Don't forget to plan where you will be looking. There is no need to memorize every cone on the course, only the ones you plan to be near, the "important" ones. Look from one important cone to the next in your plan.
Step 3) In Grid. Before you run, while you are in grid, go over the course again several times in your head, executing the plan you made before.
Step 4) After the run. Sit in your car and go over your run. Figure out where you didn't execute the plan. If the plan was to be near a particular cone, and you were five feet from it, then you didn't execute the plan correctly, and a red light should have gone off in your head. Maybe you need to adjust the plan because you were going too fast in the slow parts. Decide at this point whether your next run needs to be a better execution of the plan, or a modification of the plan.
Basically, don't use the car as an excuse, you will see a big difference in your times when you drive a course that never surprised you.
Driving Tips
Seat time, seat time, seat time. That's the best way to go faster. They say, "Before you fix the car, fix the driver". That's because there's so many techniques to improve your driving, it takes seat time to learn them all, but once you do, someone without those skills would have to spend a lot of money on their car to beat you, and probably still couldn't.
Here are a few techniques to get you started. Don't try to apply them all in your first run, you'll be too busy. But read through the whole list, then work at gaining these skills one at a time.
Look Ahead. I can't emphasize this enough. I repeat it out loud while I am driving. It's so easy to forget, but makes such a big impact on my driving. It all relates to hand-eye (and eye-foot) coordination. Look where you want your hands to drive you, and look far enough ahead to take advantage of the feedback. If you're looking at that outside cone that you're afraid you'll hit, well, you'll hit it. If you're looking ten feet in front of the bumper, the turns will keep surprising you. Imagine looking at your feet while you are running on foot! You won't be very coordinated, and you won't have a good sense of distance or speed. Same goes for driving hard corners as you do in autocross. Look ahead. You will be astounded at your performance the first time you remember to do this all the way through a course.
Slow Down to Go Fast. A common problem when you're starting out is trying to take the tight sections too fast, and not staying in control. I still remember finishing a run and saying, "Well, I didn't go very fast, but it sure was smooth," only to find out I'd gone faster by a full second! Just be patient in the slow spots. They're slow spots, after all.
Brake hard in corners. Go ahead, squeeze the brakes hard. There's no morning coffee on your dashboard, or eggs in the front seat. Once you decide to slow down for the corner, don't waste any time. If you find yourself at a crawl and you're not at the corner yet, why, you've just found out that you can brake later. Locking up your tires will not make you stop faster, so squeeze the brakes and let them do the work, not your tires.
Adhesion. Don't ask too much of your tires. For any tire/pavement pair, there's only a certain amount of traction. We'll call that 100% traction. You can use up that traction with your throttle, your brakes or your steering wheel. So if you're going into a corner, using 100% of your traction to make the turn, what happens when you ask for more traction by applying the brakes? Either you won't brake or you won't turn. Or both. Same goes for accelerating out of a corner. Ease in the throttle as you ease out of the turn. So use full throttle and full braking only in a straight line. This goes back to slowing down to go faster, and brings us to...
Smooth Inputs. You may have noticed that I used the phrases "squeeze the brakes" and "ease in the throttle". This is where you have to change your mind-set about inputs to controlling your car. You need to convince yourself that you can make your car respond better by squeezing the brakes hard instead of standing on the brakes, by rolling in the throttle rapidly instead of stomping on the gas, by turning the wheel quickly instead of cranking it around. Subtle, but it will show up in how often your car is in control instead of scrubbing off speed pushing around a corner. And it will take a lot of practice to become second nature.
Shift near redline. On the street, we don't usually shift near redline (high rpms). But in autocross, you want to be making the most of the power available to you. You'll learn to hear the motor as you drive and stay in a low gear longer. Most courses will be in second gear for stock cars. If you're shifting to third, you're shifting too soon, and giving up power (ask local drivers if this is true in your region).
Launch at 4000 rpm. Each car varies, but try to start at higher rpms than you're used to. Don't "dump" the clutch, or you'll find your wheels spinning. Let it out rapidly and find the right rpms to maintain traction. Higher horsepower cars will want to use lower rpms than less powerful cars.
Don't worry about the blinkers, wipers or horn. You're bound to hit them as you drive. Don't let it throw you. We've all done it!
More, Later... There are many more techniques for getting better times, but start with the ones listed above. After you've learned them, you'll be ready to buy a book on autocrossing (see Recommended Reading), or attend a driver's school and learn the advanced techniques of heel/toe, shuffle steer, late apex, and more.
Go to as many events as you can. Go to the ones with the toughest competition - winning something local is fun, but losing to someone fast will probably teach you more. Attend drivers' schools in your area, or travel to another region. Do some Pro Solo2 events; these are explained in more detail later in this book. They give you 12 runs on a fairly short course, with time to walk between runs and a chance to drive against real national competition.
Always remember to have fun, even when you are being stomped by some national hotshoe. You'll never stop learning - the best drivers will tell you this still applies after ten or twenty years! Remember, seat-time, seat-time, seat-time. Nothing will make you go faster sooner. And nothing is less expensive in improving your times.
Solo Etiquette
Solo II is a social sport, and most drivers are happy to give you advice and critique your runs. Ask someone with a similar car if you may follow them through a course walk. Maybe they'll even think aloud for you (don't do too much talking yourself, or you will be making them walk again). Ask if you can ride with them on a fun-run, and offer to pay the $1-$2 for the run. If you're not sure when to line up, go ahead and ask. Ask someone to look at the chalk on your tires to see whether you need more air. Ask someone to watch your run if they have time, and tell you what needs changing. They'll be glad to.
There are a few bad times to ask for advice, though. Here's a quick list:
When they are walking the course. (They're trying to memorize it.)
When they are staring into space or have their eyes closed, they're probably going over their run or plan.
When they are in grid. They are only thinking about the course.
Sometimes events will conspire to keep a good driver from competiting. It may be a broken car, it may be an injury that prevents them from being able to change tires. This is your chance! Offer that driver a ride (co-drive) in your car - make it free if you can afford to. So they use up $20 worth of tires. Not a bad price for a private instructor all day! I have gone to some of the big events, Tours, Divisionals and ProSolos and sent out an ad for a co-driver. It has been an enourmous benefit to have advice from these experts all day, and be able to walk the course with them.
Try to help out. There is more work to be done than the mandatory course-work. This is an all-volunteer organization, so help is always appreciated. Luckily, this also puts you in a position to talk to other drivers, because the veterans are helping out, too. If you share the work, they'll have more time to talk to you. Likewise, showing up early will help out the registration and tech crew, and give you more time to walk the course. Read the next section on how to help, if you're looking for ideas to lend a hand.
Everyone stays to help clean up the course and pit areas. Keeping the sites is important to everyone, so leave your pit area cleaner than you found it.
The trophy presentation is a continuation of the event, and people talk about the course or their cars or runs. It's nice to have everyone show up, to cheer the winners, even if you didn't get a trophy yourself.
How to Help Out at an Event
(You don't have to spend money to help. The region pays for all supplies)
While you're still a novice:
Arrive extra early and be a gopher during course set-up.
Help sweep the course in sandy corners.
Line the course, or mark the cones.
Fill and bring
