Home > User Content > DIY / Install Guides > DIY: Clutch Fork Squeak Fix!
Pages: << 1 2
Aciidsneaker
Marshfield
Wisconsin, US
Sweet post just wish I had a Manual
[#] Jun 01, 2007 09:00am
tCizzler wrote:
Haha yeah, i just used a jack stand wedged up against the seat to hold in the clutch pedal while i tried, but i will definately have to get someone with smaller fingers. But i'm not even sure it's necessary. I can't imagine the clutch being any smoother! You should try the other boot again if you haven't already got it. It is really easy to slip the rubber sleeve off and i'm sure it will help a lot.
Yeah, I globbed a shit load of grease all over both sections and kept working more and more grease into the "yellow" circled section for about 10 minutes. I'll probably add some more for good measure at the end of summer to get ready for a salty winter.
[#] Jun 01, 2007 09:04am
tCizzler
Canonsburg
Pennsylvania, US
Nice! Good idea
I don't like to fight, but i ain't scared to bleed..... Most don't mess with a guy like me- Eric Church
[#] Jun 01, 2007 09:05am
Dansuke
haha thx web i knew i could count on you guys to get my a solution quickly lol. The funny thing between u n me web is that ur car is at 38k im at 3k lol. I definitely should fix this while im doing my oil change this saturday lol thanks for the help and the DYI.
[#] Sep 20, 2007 08:21pm
P_O_Cluis05tC
Miami
wow...this definately helps, I thought i was the only person that had this problem but after this, I'm thinking differently. Damn Web, you are the man. I will try this and feel the difference
[#] Oct 18, 2007 11:19am
Glad this DIY worked out for everyone
[#] Oct 18, 2007 11:20am
MrScion07
Rochester
Massachusetts, US
i was wondering wut that was ill have to try this out see if it helps. i got a little squeak when its cold seems to go away as it gets warmed up tho idk if this is the squeak but ill see
[#] Feb 12, 2008 12:42pm
pallotti71687
Annandale
im in the process of doin this right now... so i take it its ok to gob the crap out of it without harming anything?
[#] Aug 01, 2008 05:37pm
If you do it the way the pictures show and in those locations, you will be fine.
[#] Aug 01, 2008 05:51pm
pallotti71687
Annandale
Thank you sir, You are a gentleman and a scholar. I can definitly feel the difference.
AWEEEESSSSOOOOOMMMEEEEEEEE...!!!!!
[#] Aug 01, 2008 10:33pm
NP....the pedal definitely feels much smoother for a while afterwards as well
[#] Aug 02, 2008 10:48am
  • The Techie
*pushes in clutch, lets out clutch... pushes in clutch.. lets go of clutch....*
"you hear anything?"
"huh? no.."
"exaccttlyyyyy.."
Decelerate your life.
[#] Aug 02, 2008 04:17pm
pallotti71687
Annandale
ooooo chyeah!!! much smoother, definitly lovin it.
[#] Aug 03, 2008 10:44am
johnniiboyyy
Island Park
ok well i just did this and my pedal is much smoother but the clutch still squeaks =[ .. any suggestions??
[#] Sep 06, 2008 03:13pm
  • The Techie
put enough in the right spot?
i would get a friend and locate the source of the squeak and grease accordingly.
[#] Sep 06, 2008 03:23pm
NightGlide
US
Thank you !
[#] Sep 06, 2008 03:41pm
aznkidlee
Massachusetts, US
Is this normal? I couldn't get the rubber to cover back the hole completely.
Will water get into the opening and cause damage?
[#] Nov 26, 2008 10:02am
It's there to prevent dust/moisture from getting into the clutch fork area and causing a lot of rust and wear. Keep trying to make it fit back the way it was.
[#] Nov 26, 2008 06:05pm
Pages: << 1 2
TOP: Home > User Content > DIY / Install Guides > DIY: Clutch Fork Squeak Fix!
